| Home > General Chat > hole saws??? where can i get one that will cut through my front subby??? | |||||||
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
20th Jul, 2008 at 03:38:51pm
20th Jul, 2008 at 03:47:41pm
Screwfix - theirs are HSS (high speed steel) and so long as you go slow and lubricate them well, they cut steel fine. Schrödinger's cat - so which one am I ??? |
20th Jul, 2008 at 03:51:38pm
What cutting speed where you using? I've drilled through 1/4" steel plate with my B&Q hole saws not problem, but that was taking it nice & slow in the drill press. Isambard Kingdom Brunel said:
![]() 646 Posts Member #: 1826 Post Whore Maldon Essex |
20th Jul, 2008 at 03:54:26pm
bit of an expert at this, lol.
20th Jul, 2008 at 03:57:32pm
arrrrrh are you meant to go slow with them then????
20th Jul, 2008 at 04:00:15pm
i have no drill-press at the moment either, well i have one but my benth is'nt strong enough to mount it! SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
20th Jul, 2008 at 05:03:34pm
On 20th Jul, 2008 clubminiflip said:
arrrrrh are you meant to go slow with them then???? YES, very slow when cutting steel, because of their diameter. A 1" hole saw would need to run at 1/8 of the rpm of a 1/8" drill to have the same cutting speed. Also plenty of lubricant (plain engine oil is fine but fancy cutting fluids are better) it's as much to keep it cool as well as lubricated. Schrödinger's cat - so which one am I ??? |
20th Jul, 2008 at 05:09:28pm
Aldi got a special on at the moment with hole saws.
20th Jul, 2008 at 05:23:38pm
off to aldi 2moz then lol SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
20th Jul, 2008 at 07:08:50pm
Best bet is to buy a decent powerful drill, that can operate at low speeds.....
20th Jul, 2008 at 07:34:13pm
i dont want to go any bigger on the holesaws than 1/1/4" maybe 1.5" absolute maximum! SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
D aldi tools have got meort out of the crappy-brown a few times
