Home > Help Needed / General Tech Chat > Offset block info
MarkGTT
Member #: 1194
Shropshire.
Hi all, just a quick question as i dont have Vizards book to hand, can i use a 1380 offset block with standard internals? Crank etc.
Also what are the benefits of the offset block?
edit: ok from what i just read all 1380 blocks should be offset?? correct?
cheers. :)
Edited by MarkGTT on 21st Jul, 2008.
yes.
A 1380 doesn't have to be offset, but if ever going to 1400, then the 1380 bore will have to be offset to clean the bore with a 1400. Makes sense? :)
MarkGTT
Member #: 1194
Shropshire.
Vegard, you’re my 'question busting' hero at the moment. *happy*
thanks for the info (again)
