Home > Help Needed / General Tech Chat > clutch slip!!!!!!!!
greymini78
Member #: 2408
surrey / ewell area.
Youre not gonna believe this but the clutch is slipping in third and fourth. Am i right in saying this is a buggered clutch? or is it the throw out on the arm? it shouldnt be clutch its a new pre verto with orange diaphram.
Spec of engine. Type of clutch plate. Boost pressure.
We're good, but we're not fucking psychic.
greymini78
Member #: 2408
1293,8psi boost,vmax suck through charger,2.9 diff,clutch is uprated cant remember the exact details, i remember it being the next one up from standard if that helps sorry to be vague, as i said i tried the throw out bolt but no joy. is it worth bleeding the slave again?
Turbo Tel
Member #: 588
Delaware, USA
New clutchplate , Orange diaphram should be OK at 8psi, Bleeding it would not help as that mostly affects releasinng not the clamping pressure.
Is the clearance to the bolt on the wok OK? could the clutch seal be leaking causing oil on the plate?
There are some posts about making sure the straps are level which gives the best clamping pressure, search around.
greymini78
Member #: 2408
cheers tel
Ric
Member #: 36
Basingstoke
yeah, that should be enough to hold that. I think alexb was running an orange and he was hitting 16 psi with no slip. I reckon it's an adustment issue.
greymini78
Member #: 2408
Update on clutch and mot. Sussed the clutch problem, orange oil seal!! and turbo metro plate . so i binned all that and replaced with orange diaphram and ap road race plate, i think its bonded and riveted should hold up now!! p.s also put in brown seal from mpi? apparently they r much tougher. pis soon.
