Home > General Chat > ot Fitting a bov to a van
mokle
Member #: 2488
Edinburgh
Does any one know where or how to fit a dump valve to a renault master?
I want to fit my spare one to the works van for a laugh.
Any help would be great.
I can see the intercooler pipes so know roughly where that goes, but finding a take off for the little pipe thing (forgotten the name of it) is proving difficult.
Tony
deisel?
im not too sure you can..
im probally wrong.
it will be difficult as it wont create any vacuum because the engine speed is controlled by how much fuel is let in not much air as in a petrol engine.
so becuase the is no butterfly it cannot create vacuum because there is no major restiction in the intake system when the throttle is off.
the way most create a vacuum for things like the brake servo is by using a vacuum pump driven from the cam.
new VAG PD engine do have some sort of setup that creates vacuum on over-run i believe but i havent looked into it yet as i cant be assed...
if you rigged it up to a solenoid which was actiated by the pedal then this would be possible but pointless in my eyes.
mini93
Member #: 2017
Warwick.
you can get diesel DV but really, i dont think theres much point....its just gona take ages once charge has been dumped to build up pressure
David.
Turbo Shed
Member #: 30
Epsom, Surrey
dont worry about the dump valve, get a bleed valve!!!!
Ben H
Member #: 184
Melton Mowbray, Pie Country
That doesn't work on many diesels either. Quite often the actuator is driven off vacuum not pressure, so it is all arse about face,.
http://www.twin-turbo.co.uk
Turbo Shed
Member #: 30
Epsom, Surrey
it worked on a belingo
Jay#2
Member #: 648
Northern Ireland (ex AUS)
You can get diesel DV kits on ebay, don't know how they work without a throttle but all the Chavs have them on their Astras. Now all the VAGs have comp surge happening, still haven't figured that out yet!
On 7th Nov, 2008 Nic said:
naeJ
m
Maybe they use a switch on the throttle pedal or clutch.
