| Home > Help Needed / General Tech Chat > What size tap small bore block Main's | |||||||
27th Jul, 2008 at 07:07:15pm
Howya lads what size tap and what treed for the main bearings on an A+ small bore the I have been evicted from my garage by builders for the week and we need to run a tap trough the main bearing bolt holes on spanners block during the week so its off the local tool supplier we taught it might be UNF but that’s as far as 2we got,
On 17th Feb, 2009 Rob H said:
27th Jul, 2008 at 09:57:10pm
7/16 UNF I recall. On 13th Jul, 2012 Ben H said:
27th Jul, 2008 at 10:24:09pm
On 27th Jul, 2008 Vegard said:
7/16 UNF I recall. you recall correctly lad,. |
