Home > Help Needed / General Tech Chat > HIF 44 Turbo carb needle and fuel pressure
no.1racer
Member #: 1163
Malvern, Worcestershire
Hi. Just wondering what needles everyone is using in their HIF 44 carbs. I have just managed to get my car running this week, however tbh it runs awfully. When cold it idles ok but as soon as the throttle is opened or when the engine starts to get warm, it just cuts out. Also, on the over run it seems to poor fuel out of the overflow.
What i am asking really is what needles everyone is running. Mine has BAN stated on it.
Also what is the approximate fuel pressure to run with the correct needle.
Thanks
Tom
Kean
Member #: 341
aka T2clubby
South Staffs
Overflow? on a turbo carb?
no.1racer
Member #: 1163
I have made an overflow by putting a t- piece in the fuel line. Simply because i have a friend whos carb had an overflow pipe originally fitted and seemed to work pretty well. So should i take off the t-piece and just run a single fuel line then?
We need more info on your fuelling set-up.
Is it all metro turbo bits including the pressure regulator. pump carb and plenum?
What side are your feed and return fuel hoses?
What pressure have you set the idle fuel pressure at?
If your overflow is 'open' then you won't fuel correctly on boost. This needs sorting first.
Turbo Tel
Member #: 588
Delaware, USA
heres a link to the pics and TD's thread (link inside) will show you how to plumb in,
http://www.turbominis.com/forums/index.php?p=vt&tid=217478
Terry
no.1racer
Member #: 1163
Thanks for the help. Will try re plumbing it and will see how it goes.
Tom
