Home > Help Needed / General Tech Chat > where is my brake fluid going
b12
Member #: 247
Kent/Surrey Borders
wierd ..
my van for some reason, i fill the brakes up , bleed them nice,
then come back to the car 2 days later and the fluid is all gone, and no apparant fluid on the floor !!
where on earth can it be going .... anyone have a clue ?
i rekon its a leaky rear brake, but aint had the wheel off yet , but just thought i would ask
S
TurboLessTosser
adam1330
Member #: 238
essex
that would be my first guess, the rear wheel cylinders.
b12
Member #: 247
Kent/Surrey Borders
Do you know in all my years of playing with minis I have never had to change a rear cylinder !!! Lucky Or what
Are the bastads to get off ??
Can I leave the backplate in place ?
S
TurboLessTosser
adam1330
Member #: 238
essex
yeah easy enough, no need to remove the backplate.
but beware as the brake pipe has a tendancy to snap!
not a major problem i know, but it can be annoying if you cant get a new piece untill the next day!
giallofly
Member #: 164
The Stig..
Newport Pagnell
Under the master cylinder??
Try feeling under the steering columb/pedal area for the fluid.
Nick
Member #: 154
Midlands
have fun gettin the rear wheel cylinder circlip back on dude. i fucking hate doing them!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
does it have a late servo?
alex
AlexF
b12
Member #: 247
Kent/Surrey Borders
it has no servo ; Havnt thought about checking under the carpet though !!
Strange that there is nothing on the road though isnt it !!
Steve
TurboLessTosser
evolotion
Member #: 83
Glasgow, Scotland
was guna suggest teh servo *tongue* my old mayfair had a brake fluid fileld servo, and shortly after a brake fluid filled engine..
Denis O'Brien.
A HA! The rear wheel cylinder circlip!!
Who wants to know my special trick gleaned when I worked at a mini specialists that works and lets you get the clip on first time every time?!?!?!?
Nick
Member #: 154
Midlands
cut it in half then gaffa tape it back round the cylinder?
erm not quite!!!!
The hard part of the job is holding the cylinder in place while you struggle with the clip.
So the way to do it is......
Get a pair of mole grips, more or less any will do.
Clamp them onto the edge of the hub (e.g. next to the wheel stud) with the mole grips 'backwards' or so that the fixed jaw is towards the drum backplate.
This has the effect of pushing the cylinder firmly into the backplate, leaving you with 2 hands free to fit the clip. You will be suprised how easy it is when you haven;t got to struggle with the cylinder at the same time!
which mini specialist did you work out out of curiosity? *smiley*
worked for a place called evesham mini centre which was unsuprisingly in evesham!! Was the local place that I used to use for all bits and bobs I needed and so got to know the gaffer well and so used to work there during my time off from university during summer and xmas etc.
You would think that working with Minis all the time would be fun but really it just used to spoil your hobby, after working on peoples run into the ground sheds doing bl**dy balljoints again and again, by the time you got home the last thing you wanted to do was go in the garage and work on your own car. But having said that there was the odd enjoyable job such as rebuilding a Mini Moke that then went to Portugal, but as well as that you soon learn how to do the common jobs quickly and also the tricks that make them easier. That wheel cylinder one is great.
evolotion
Member #: 83
Glasgow, Scotland
own up.. whos bought the special wheel cylinder circlip putter-onner tool?
Denis O'Brien.
b12
Member #: 247
Kent/Surrey Borders
Grrrrrrrrrrrrrrr
Well loadsa faffing about later
Changed the reqar cylinders as I had nothing better to do with my day ! then changed one of my calipers
filled up bleed it all nice
THEN I noticed it
the fluid around the 4 way brake limiter valve thats bolted onto the bulkhead
New I think they are about 70 quid grrrrrrrrrrrrrrrrrrrrrrrrr
Anyone on here have one they can sell 2 me ??
PLEEEEEeeeeeeeeeeeeeeease
S
TurboLessTosser
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Evo,
Me, I got one and it works a treat!
Steve,
bin it and get an adjustable bias valve!
Alex
AlexF
b12
Member #: 247
Kent/Surrey Borders
tell me more about the adjustable bias valve!
I have no idea what it is !!!!!!!!!!!!!!1
TurboLessTosser
Nick
Member #: 154
Midlands
yeah, its a lot cheaper for an adjustable one than a new limiter valve. my mate had one go a while back. i think they're about £120 brand new.
all it does is lets you adjust the front/rear split of the brakes i think. and doesn't cost the earth.
