| Home > Technical Chat > cylinder head identification | |||||||
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
27th Aug, 2003 at 11:19:01pm
how do i identify whether or not i have a turbo cylinder head or not without taking it apart to measure the exhaust valves i.e. sodium filled SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
2nd Nov, 2003 at 03:16:42pm
You can tell if it has sodium valves by the thickness of the valve stem, they will look considerably thicker than the inlets.
15th Nov, 2003 at 03:56:46pm
As the valve stem is bigger. Is the retainer bigger as well or are just the valve collets different? On 13th Jul, 2012 Ben H said:
27th Feb, 2004 at 09:32:57pm
The valve seam is visably bigger... as are the guides and as the collets have to match, the spring cap is slightly bigger. The springs are all the same size...
AlexF |
117 Posts Member #: 144 Advanced Member |
7th May, 2004 at 02:46:20pm
i have got both turbo and std cooper head, the turbo head has got dual valve springs, is this std? and the springs on my cooper head are about 5mm taller than my trubo ones!
7th May, 2004 at 03:24:08pm
double valve spring is std on the turbo Team www.sheepspeed.com Racing
11 Posts Member #: 67 Member Hitchin Herts. |
16th May, 2004 at 12:11:00pm
Hi all.
16th May, 2004 at 01:29:39pm
very hand site mate! Team www.sheepspeed.com Racing
