| Home > Help Needed / General Tech Chat > Refresh my memory, castor angles | |||||||
6th Aug, 2008 at 06:17:48pm
Just done a lot of work on my suspension and am in the process of setting up my castor angles, I remember turn the wheels each way and measure the camber but what do you do with these mesasurements?
Edited by paul wiginton on 6th Aug, 2008. I seriously doubt it! |
6th Aug, 2008 at 07:04:38pm
the way I mesaure Castor is to drive the car no turn tables get a helper to turn the wheel in 20 deg and level the gauge and bubbles then turn the wheel out 20 deg and take the readiing the adjust to the desired value I normaly run 3 -4 deg factory is 1-3 deg no less then one no more than 5 imo on the race cars I run 2.2 deg neg camber and 6 mins toe out and .5 neg camber on the rear and 1.2deg toe out but this makes the car very skitty my road car runs 10 mins toe in and .5 deg camber on the rear and 1.5 deg neg camber in the front 1/16th toe out and 3 deg normal feal good but can have a tendency to wander,
On 17th Feb, 2009 Rob H said:
6th Aug, 2008 at 07:46:08pm
If I had a gauge with bubbles on Id be sorted thanks to that but I have the cheap plum bob type from Minispares
6th Aug, 2008 at 08:49:23pm
the top ball joint needs to be 15mm further back than the botton one, this equates IIRC to 5- 6 degs , i think its 15mm could be 19,mm,
Edited by fastcarl on 6th Aug, 2008. |
6th Aug, 2008 at 08:55:07pm
Ho fart never used one maby there is some one elce here that has sory Paul.
6th Aug, 2008 at 09:46:15pm
Sussed it. Found instructions on the Minimania site.
7th Aug, 2008 at 10:13:03am
Do you have the link Paul?
7th Aug, 2008 at 10:20:50am
On 6th Aug, 2008 fastcarl said:
the top ball joint needs to be 15mm further back than the botton one, this equates IIRC to 5- 6 degs , i think its 15mm could be 19,mm, get a protractor out and draw it up, measured on a flat of the bolt on the pin Is this when the car is sat on the deck, as I would expect, or at full droop? Might be hard to check/measure without a pit or ramp :( |
7th Aug, 2008 at 10:42:00am
Tom,
7th Aug, 2008 at 06:12:56pm
Thats the one Graemec, Ive now set mine, it was all over the place , it took me hours
7th Aug, 2008 at 06:38:26pm
I *think* I've managed to get mine set to 3 degress caster and 1.25 degree -ve camber. Not ideal but at least a starting point - I got bored after a while! |
7th Aug, 2008 at 07:27:54pm
That sounds a descent setting, I put mine to 1.25 -ve camber and 3.5 castor
17th Oct, 2009 at 12:39:40am
whats mins in mm's? "Turbo's make torque, and torque makes fun"
17th Oct, 2009 at 09:37:09am
It depends on how close to the pivot point youre measuring the minutes
17th Oct, 2009 at 11:03:46am
granted, but is there a set arc length people use?
17th Oct, 2009 at 05:09:28pm
Is this for caster/camber Joey? I think you'd struggle to measure them in mm.
17th Oct, 2009 at 05:33:00pm
im just wondering in general, my laycock tracking gauges measure in mm, and ive been reading a few books/thread ont he web, and alot of people quote mins
17th Oct, 2009 at 05:38:52pm
1 minute is 1/60 of a degree
