Home > Help Needed / General Tech Chat > bad news
mark4765
Member #: 249
*frown* ive got my mini running at last and was running spot on....no driveshafts in yet so havent driven it,only run it for 10 mins tonight and a nasty rattle has appeared *crying* when i depress the clutch the noise completely goes,and reappears when clutch is let out....im pissed off
mark
giallofly
Member #: 164
The Stig..
Newport Pagnell
Straight cut drop gears clashing together??....
They will seem ok on start up but once the oil thins they often seem to make a chatter.
Quite normal.
Edited by giallofly on 12th Aug, 2004.
mark4765
Member #: 249
its quite a bad rattle though jon...i'll try it in the morning when oil is cold...if not engine out time *frown*
mark
Edited by mark4765 on 12th Aug, 2004.
minimark
Member #: 19
newcastle
if the engine revs freely with clutch depressed sounds like drop gear chatter.
as jon says drop gears rattle like hell.
mark4765
Member #: 249
cheers lads,maybe me being paranoid then! its really rattly though ,just like the old engine i replaced with knackered drop gears....when i depress the clutch the engine does drop by about 200 rpm aswell
mark
giallofly
Member #: 164
The Stig..
Newport Pagnell
Fitting up the drops to factory tolerences is a bit of an art. It is all in the hayes/whatever manual and a bit of a polaver!
A drop 0f 200rpm is fairly livable IMO,if it was 6/800 i would worry and seriously lookover the bottom end.
My engine last year seized solid when them clutch was depressed, a freaky fault!
Remember this engine is still tight of rebuild and will take many hours of use to loosen up.
I am sure it is fine.
I thought this when I had my first engine with SC drops, it was nothing, just the drop gears
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
you shouldnt get any rpm drop by depressing the clutch...
your crank end float is wrong if you do!
alex
AlexF
even with a very heavy diapraghm? would of thought you'd get a bit as they'll load the thrusts a lot.
Yeah I thought that with such as a grey or double grey diag. then the force on the thrusts is enough to make them tight regarless of whether you have a correct endfloat or knackered one?
My old clubby estate had an art to getting it started, one bit of which was not to put your foot on the clutch as it wouldn;t turn on the starter if you did......
mark4765
Member #: 249
crank endfloat and drop gears were set to the lower factory tolerances...im probaly wrong but my opinion is that the flywheel bolt has come loose somehow,which would explain the symptoms...im going to start it shortly and listen from cold...im also going to record the sound if anyone wants to hear it and diagnose if they can...stick your email addy down and i'll send the clip
regards mark
Edited by mark4765 on 13th Aug, 2004.
mark4765
Member #: 249
just started and no noise whatsoever when cold *happy*
mark
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Mine doesn't drop anyone on a grey...
Mark, I think your hearing transfer gear chatter!
Alex
AlexF
minimark
Member #: 19
newcastle
you can`t talk in my car never mind chatter.
