| Home > Help Needed / General Tech Chat > Timing Avonbar Phase 2 Cam | |||||||
9th Aug, 2008 at 02:55:34pm
Hi guys,
9th Aug, 2008 at 05:05:11pm
as you said really, just time it to 108 deg btdc, and make sure it is BTDC and not ATDC lol.
Edited by Joe C on 9th Aug, 2008. On 28th Aug, 2011 Kean said:
![]() 514 Posts Member #: 2169 Post Whore Malta (Ex. Scotland) |
9th Aug, 2008 at 05:07:09pm
You mean 10 thou before full lift and 10 thou after,right Joe? Warning:Stig in Training
9th Aug, 2008 at 07:57:51pm
9th Aug, 2008 at 10:56:14pm
On 9th Aug, 2008 Vegard said:
Time it at 106. Ahh, just got in from timing it didnt see your post, was that 2 degrees to allow for chain stretch? I've got it dialed in at 107.2 degrees to allow for a little stretch, think this will be ok? Alot easier to do than I thought, don't see why people make such a fuss about doing it to be honest, I know its important to get right but as long as you understand what your'e doing it's fine? How is it possible to time a cam 180 degrees out? By setting TDC with the cam sprocket 180 degrees to the crank sprocket? Cheers |
9th Aug, 2008 at 10:58:01pm
It'll be OK. No, you cannot time a camshaft 180 degrees wrong. However, it depens if it's crankshaft or camshaft degrees On 13th Jul, 2012 Ben H said:
9th Aug, 2008 at 11:21:55pm
Ahh no worries then, im sure ive dont it right! Nice one!
10th Aug, 2008 at 09:41:29am
On 9th Aug, 2008 mini13 said:
as you said really, just time it to 108 deg btdc, and make sure it is BTDC and not ATDC lol. Been thinking about this, you say make sure you time it BTDC. Im confused, surely its always ATDC becuase, when you find TDC with the pulley dots lined up, the lobe only starts to lift after this point, when you rotate the engine anticlockwise from the flywheel, so thats ATDC? Then you find the peak of this lift by noting the angle 10 thou before and after max valve lift and averaging it to find the (hopefully) angle you require for the cam? Can anyone correct me because im confused and paranoid ive done it qrong now lol. Cheers |
10th Aug, 2008 at 10:30:51am
inlet is after tdc . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
10th Aug, 2008 at 10:51:51am
Yeah I know, thats why im confused. I've timed it on cylinder 1 inlet valve at 107.2 degrees.
![]() 171 Posts Member #: 621 Advanced Member nsw austalia |
10th Aug, 2008 at 11:26:26am
On 10th Aug, 2008 richminiturbo. said:
Yeah I know, thats why im confused. I've timed it on cylinder 1 inlet valve at 107.2 degrees. How it is possible to time it "BTDC" when inlet is after TDC?? time it in turning engine backwards, sound stuped but iv done it lol 1152cc turboed mini clubman, most powerful 1.1L a-series?
10th Aug, 2008 at 11:40:15am
Ahhhh ok i get it.
it didnt come with a timing disc (which I have now) or any spec/instruction sheets! So im abit clueless about how it should be setup.
