| Home > Help Needed / General Tech Chat > Duplex Timing Gear & Chain | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
11th Aug, 2008 at 01:36:18pm
As my new cam is leaking once again, fck knows whats going on there. im going to change to a Duplex Timing Gear & Chain.
Shit Happen's |
11th Aug, 2008 at 02:28:29pm
194 Posts Member #: 2873 Advanced Member Milton Keynes |
11th Aug, 2008 at 02:30:35pm
get the duplex chain and the gears, also get u'r self a chain tensioner, make sure the oil can also get to the chain and gears for lubrication |
11th Aug, 2008 at 06:18:18pm
So these the things i need ?
Shit Happen's |
12th Aug, 2008 at 01:51:56am
Yes, those bits will do.. You don't actually need a new timing cover the old one will do but with either you may have to adjust it a bit (with a hammer) to clear the duplex gears, do a search on that..
12th Aug, 2008 at 08:09:56am
When I put my duplex on recently, the dots didnt perfectly line up with each other through the centreline of the crank and cam ends.
12th Aug, 2008 at 11:34:43am
TBH Iwould always go for the vernier duplex Kit now I have all the kit for making my own off set kit but at the price of labour it works out cheeper to buy the Vernier and it lighter which is a bonus,
On 17th Feb, 2009 Rob H said:
12th Aug, 2008 at 11:36:53am
They look cool aswell, shame you cover them up really lol |
12th Aug, 2008 at 12:38:27pm
dont forget you will need 2 countersunk allen screws, as the wider gear will catch on the std bolts heads "Turbo's make torque, and torque makes fun"
12th Aug, 2008 at 12:54:39pm
Do you have to countersink the holes under the crank sprocket on belt drives aswell?
13th Aug, 2008 at 01:19:52pm
On 11th Aug, 2008 Tweaked said:
get the duplex chain and the gears, also get u'r self a chain tensioner, make sure the oil can also get to the chain and gears for lubrication Thanks for the help lads. How do i make sure the oil get to the chain and gears ? I thought that happens naturally. with oil coming from that hole On The cam retaining plate ? Cheers. Shit Happen's |
14th Aug, 2008 at 05:10:24pm
Shit Happen's |
14th Sep, 2009 at 07:44:06pm
On 12th Aug, 2008 joeybaby83 said:
dont forget you will need 2 countersunk allen screws, as the wider gear will catch on the std bolts heads On 11th Feb, 2015 robert said:
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
14th Sep, 2009 at 07:53:19pm
correct on both counts, ive always used drum brake screws and they work just fine. |
14th Sep, 2009 at 07:53:44pm
you are right! |
14th Sep, 2009 at 07:59:38pm
Yes, just make sure you make the countersink deep enough.
14th Sep, 2009 at 08:06:09pm
Smashing Thanks.
14th Sep, 2009 at 08:15:31pm
On 14th Sep, 2009 apbellamy said:
Smashing Thanks. Groovy Baby On 26th Oct, 2004 TurboDave16v said:
14th Sep, 2009 at 08:50:33pm
Smashing Thanks. Groovy Baby Dead sexeee... On 13th Jul, 2012 Ben H said:
14th Sep, 2009 at 09:07:30pm
lol at the kiddies Edited by apbellamy on 14th Sep, 2009. On 11th Feb, 2015 robert said:
