Home > Help Needed / General Tech Chat > Best Option ?
Markie_D
Member #: 1660
Formally Mini_Uk
London
Had my, i know alot about carbs mate round helping me rebuild The carb tonight. he striped it etc. then started putting it back Together.
He seemed to know what he was doing. till i heard him say, Opps.
Knowing he fucked somthing up :(
He kept turning this screw untill it come off, getting stuck inside The hole of the carb :(. i said u COCK lol
He said he will pay for the best way out of it.
So what's the best option i can do.
I have few freads left inside the hole.
Cheers lads.
Shit Happen's
Mikes1098
Member #: 2190
South Carolina, USA
Drill.....carefully..if you were re-assembling it should not be frozen at all and should come right out with an EZ-out....but I have never got those damn things to work...
Edited by Mikes1098 on 15th Aug, 2008.
Markie_D
Member #: 1660
Formally Mini_Uk
London
Guess i'll have to try that then. have to get a new screw.
But only comes as a kit.. £15 *surprised*
http://www.sucarb.co.uk/ExplodedImageCoord...roductId=33966#
Shit Happen's
Eazy-outs are rarely sucessful at small diameters - by the time you have drilled the hole for them, the metal left is so thin the easy-out tends to spread it out and the broken bit grips tighter.
First try a left hand drill bit to drill the hole (assuming you have a power or cordless drill that will run backwards). What happens is as you drill the hole and the drill snags, it unscrews the broken bit anyway.
Typical example here but there are places that sell them in individual sizes.
http://www.northerntooluk.com/products.asp?partno=150272E
Rod.
Edited by Rod S on 15th Aug, 2008.
philc
Member #: 1346
bromsgrove
i am sure you would be able to pick up another carb for the same price or less as eazy outs. the time spent sorting it you may aswell but another carb.
hahah 'my friend'
come clean, bet it was you! lol
what about using somethign thin and sharp and trying to 'tap' it anticlockwise??
Markie_D
Member #: 1660
Formally Mini_Uk
London
On 15th Aug, 2008 joeybaby83 said:
hahah 'my friend'
Lol I promise it wasn't me :) i'd say if it was, as ive come clean before with Fcks up lol
I'll try that first with what you said.. if not then i'll go from there.
Thanks for your help lads :)
Shit Happen's
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Well at least you can take good pictures. Most people just post blurry hash taken on their phones.
On 7th Nov, 2008 Nic said:
naeJ
m
They look right when you've had a few beers *wink*...which is probably for the best on here, many people type whist under the influence of them damn alcohols! Lol
Markie_D
Member #: 1660
Formally Mini_Uk
London
I should ask matt for a job lol as my camara skills are better then My mechanic skills. *tongue*
I found the screw i need on it's own :)
https://www.sucarb.co.uk/ProductDetail.aspx?Id=30871
I drilled a very small hole on the broken part.
It seems very brittle.
Shit Happen's
you might be able to knock / push a small torx into the hole you've drilled and undo it.
Markie_D
Member #: 1660
Formally Mini_Uk
London
Ive just tried something along them line, but it just crumbled :(
Bugger that...
Shit Happen's
New carb body. Put a post on here asking for an old, f**ked carb - so long as the body is good.
Markie_D
Member #: 1660
Formally Mini_Uk
London
Think i'll do that.
Quick Question. is the None Turbo HIF 44 SU Carb Dashpot Damper the same as the Turbo Carb damper ?
Edited by Markie_D on 15th Aug, 2008.
Shit Happen's
Damper (moving part) is the same I believe... Damper body is the same apart from the groove (which is redundant, but a good weigth saving)... LOL
Markie_D
Member #: 1660
Formally Mini_Uk
London
This part :)
http://cgi.ebay.co.uk/Mini-HIF-44-SU-Carb-...p3286.m20.l1116
The shaft is bent on mine. *surprised*
I best get one :)
Shit Happen's
Yes, that's the same - or if it isn't, I've been using the wrong one for years.
