Home > Help Needed / General Tech Chat > carb creation
Kean
Member #: 341
aka T2clubby
South Staffs
Is it possible to modify a normal hif44 to run turbo application ??
I have access to a couple of these but the proper turbo carbs are thin on the ground at the mo
yes it is possible, turbodave posted how to a while ago, it may of been on miniclassic. He's checking out the strip clubs and drag strips (may drag clubs too?) in the US at the moment, he'll be online monday, no doubt he will tell you how then.
You can buy the turbo carbs new from burlens.
Kean
Member #: 341
aka T2clubby
South Staffs
Great dont suppose you know the carb part number??
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
HIF turbo
there is only one...
Alex
AlexF
ive got it at home. il try remeber.
there are two different numbers... *smiley* couple of seal varients iirc
