| Home > Technical Chat > Red Dot Cones | |||||||
![]() 143 Posts Member #: 1506 Advanced Member Cheshire |
16th Aug, 2008 at 06:37:51pm
Anybody using them?
Check out the (slow) progress at.......
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
17th Aug, 2008 at 04:41:14pm
Slowly. After a few years, I still have my hilos wound down fully and the ride height is still up a fair bit. Next time I'd fit used cones with hilos and wind 'em up. Bugger off, I'm getting there. |
17th Aug, 2008 at 05:00:20pm
New red dot cones soon to hit the for sale section then I think :) Check out the (slow) progress at.......
122 Posts Member #: 2023 Advanced Member nr Portsmouth ,Hampshire |
17th Aug, 2008 at 07:32:15pm
Why not just cut down your hilos to allow you to correct the ride height . |
17th Aug, 2008 at 08:27:27pm
Sounds like a bloody good idea! Why didn't I think of that.
18th Aug, 2008 at 08:47:45am
I had to modify my hi-los to make them go lower. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Aug, 2008 at 09:01:31am
Thanks chaps.
Edited by dn89mini on 18th Aug, 2008. Check out the (slow) progress at.......
18th Aug, 2008 at 09:16:38am
might be less than you think the car will drop 3 times whatever you take of the cone (for front susp) "Turbo's make torque, and torque makes fun"
18th Aug, 2008 at 09:23:08am
the sill height depends on tyre size really. but my front bottom arms are set level at rest.
Edited by wil_h on 18th Aug, 2008. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Aug, 2008 at 09:36:28am
Good stuff thanks. Check out the (slow) progress at.......
18th Aug, 2008 at 10:52:35am
On 18th Aug, 2008 wil_h said:
3mm will lower the front around 1"
Which is it, millimeters or Inches
18th Aug, 2008 at 11:56:32am
I thought it was 1:3 on the front and 1:5 on the rear. I took about 5mm off of mine and its pretty low now even with the locknuts. |
19th Aug, 2008 at 10:19:11pm
I run my wheels concentric in the arches. I've also got flat hilo lands so that the spring rate is more exponential. It's pretty stiff. Bugger off, I'm getting there. |
20th Aug, 2008 at 08:31:13am
On 18th Aug, 2008 gavin@minispares.com said:
I thought it was 1:3 on the front and 1:5 on the rear. I took about 5mm off of mine and its pretty low now even with the locknuts. This is correct! On 13th Jul, 2012 Ben H said:
