Home > Wanted > bonnet lifting brackets & radiater pipe
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
hello all
As title just want to lift the back of the bonnet to give a bit more air flow and clearence also does any one know if there is such a think as
(the radiator pipe off the water pump, I need it to bend down as I have ic pipe running there and air filter pipe also running there and need as much room as posiable)
Thanks in advance
mpe
Member #: 4743
just wondering that myself - I know some people do lift the rear of the mini bonnet for clearance and / or airflow, but I can't say if the airflow is enhanced. Perhaps the brackets are a do it yourself job too.
brackets you will have to make yourself
philc
Member #: 1346
bromsgrove
do you mean by lifting the bonnet by the skuttle pannel? if so, get a bonnet pin kit, and put a piece of pipe over the top, this will lift the bonnet up like this
pot_dan
Member #: 326
bradford, west yorks
i dont have a pic of mine but its lifted enough to stop hot start problems and also enough that everyone i pass tells me its open. lol but if you just fit it so that the bolt closest the windscreen sits on top with a washer to wedge the bracket. and the one towards the front of the car fitted normal. hope this makes sense to you. lol
http://turbominis.co.uk/car/105/
pot_dan
Member #: 326
ok so i do have a pic of mine ^^^ lol but not of how its fitted. lol
