Home > 998cc > ported 202. it is possible to get it to flow decently on the exhaust
Sir Yun
Member #: 1592
Smart Guy!
well. i have beavered away on a 202 head and with the stainless MS valves and quite a bit of effort I managed to get (at 11mm lift) 60 CFM@10 inches of water on the exhaust.
which basicly means that is flows more or less the same than a pretty decently ported st3 12G940 with a 29mm exhaust valve i have tested.
intake is yet to be finished but i suspect quite a bit of flow there as well.
all in all i think that while it is a huge amount of work, a 12g202 is a very viable option for a turbo head as you can get pretty decent flow ( probably down to the ''taller'' ssr which gives you room for creating a nice radius) and a low compression without resorting to much exotic work and keeping enough meat to keep a gasket alive..
eaton_mini
Member #: 1649
West Sussex - dreaming of forced induction!
Blimey, and I just happen to have one of these forsale (bog standard though!)
LMAO
I'm using one on my 1100T as well. Any pictures?
eaton_mini
Member #: 1649
Who me or sir yun LOL
Sir Yun
Member #: 1592
Smart Guy!
there are some more in the pic section.
It looks a lot like most other pics of worked ports but less tidy.
But there is quite a lot of subtle shape change near the SSR and the parts you can not see and have to work blindly and of course a LOT of guide boss removal. Port runners are only very slightly increased/reshaped so port speed should be nice and high.
Edited by Sir Yun on 19th Aug, 2008.
Sam
Member #: 1686
Oxford
just out of curiosity does anyone know what the maximum a 940 casting head can flow upto?
OMG Robert that's a big one
looking good,
how many hours does it owe?
lol
I just skimmed my 202 after HOURS of work, to get 9:1 comp. I then found a crack between a water channel and the combustion chambers. That's because so many of you wankers run without anti freeze. Bugger!
Sam
Member #: 1686
Oxford
was that a viking rage moment? :)
Edited by Sam on 4th Sep, 2008.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
I can quarantee that that head was run with anti freeze though Vegard! It was the original head from my time machine 1100, which had covered 58000 since new when that head was taken off. The block and other parts where spotless, heck I didnt even change the waterpump on it... And it had the cast impellor.
I seriously doubt that rust is the case with this one...
Also the head isnt yours*tongue*
Edited by miniminor63 on 4th Sep, 2008.
Anyway, it was corroded inside. Maybe 70-ies antifreeze was junk!
No, it isn't mine, you're free to collect it anytime *tongue*
miniminor63
Member #: 672
Oslo, Norway
I guess it was rusty from storage yes, but severe pitting on the inside is not what caused this, it must have been some trouble while casting, or the grinding we have done on it... The block was spotless on the inside when I rebuilt that engine
Anyway.. Scrap now unfortunately..
miniminor63
Member #: 672
Oslo, Norway
yes, do you have another one for the 1100?
I've got three 295s and two 202s :) However, I'm using a 202 in spite!
miniminor63
Member #: 672
Oslo, Norway
so why did you ask me for one to use? *tongue*
Because I aquired these recently. Damn, this thread has gone off..
miniminor63
Member #: 672
Oslo, Norway
*happy*
