| Home > Help Needed / General Tech Chat > can anyone shed some light? rwd subframes | |||||||
20th Aug, 2008 at 11:44:31pm
hi guys, im lookin go pick your brains Yes i moved to the darkside |
444 Posts Member #: 2885 Senior Member |
20th Aug, 2008 at 11:52:37pm
well you need the hubs and everything that supports them (sus. arms tiebars cones damper) from a front sub but with the mountings to fit the rear sub points of a mini shell
![]() 168 Posts Member #: 1772 Advanced Member Leicestersheershire |
21st Aug, 2008 at 06:59:18am
On the Coupe, we use a whole front end subframe in the back. The bits are available to lock off the steering and for the gear change.
Tim Rowe
52 Posts Member #: 1655 Advanced Member Norway |
21st Aug, 2008 at 07:22:27am
I think Zcars may help you...
21st Aug, 2008 at 08:12:58am
no its not, as its crashed |
21st Aug, 2008 at 09:29:19am
On 21st Aug, 2008 codd_coupe said:
On the Coupe, we use a whole front end subframe in the back. The bits are available to lock off the steering and for the gear change. that picture is great, helps alot with one of my ideas, edit, hows the handbrake work in this layout.. is it like a line lock on the rear circuit? h
On 21st Aug, 2008 Minibar72 said:
I think Zcars may help you... This was bought from them back in 2004: This car is a Mini Pickup...with a turboed Suzuki Swift 16v, 4wd!!8-) It is pretty quick!! that swing arm is what i saw at mitp (maybe not that actual one ) but with the rose joints and the engine- drivetrain layout is of the same as my plans with the diff in the back, iirc the swift 4wd uses the justy drivetrain so thats something to think about
thanks alot, any more pics?
Edited by Brett on 21st Aug, 2008. Yes i moved to the darkside |
21st Aug, 2008 at 10:02:21am
On 21st Aug, 2008 miniminor63 said:
no its not, as its crashed ![]() Is it? Terminally? On 13th Jul, 2012 Ben H said:
21st Aug, 2008 at 10:18:25am
shame I always loved that pickup Team www.sheepspeed.com Racing
21st Aug, 2008 at 11:10:01am
i have emailed zcars, and with in 15 minutes Chris Allanson from zcars replyed with pics, looks like i am buying from them when the time comes :) Yes i moved to the darkside |
21st Aug, 2008 at 11:11:45am
they have 2 designs::)
21st Aug, 2008 at 11:15:53am
the other 2 pics dont seem to want to upload
21st Aug, 2008 at 11:18:08am
no its not, as its crashed ![]() Is it? Terminally? He is rebuliding it as we speak...but slowly! New turbo, new engine-management and so on... He's looking for +300bhp. |
21st Aug, 2008 at 11:20:11am
PS! Whats the price? |
21st Aug, 2008 at 11:27:28am
VERY slowly according to Tony, he had not done anything the last year at least |
21st Aug, 2008 at 12:37:25pm
I've had the hubs modified (doesn't need much to do it), so that I am using MGF calipers. Any machine shop can easily do the mod, and gives you a proper self adjusting handbrake mechanism, as I used the cables and lever too. Tim Rowe
21st Aug, 2008 at 11:55:49pm
PS! Whats the price? the price for the arms is £220 each + cv's plus brake setup plus obviously the coil overs plus the bespoke drive shafts at £110 each plus the material cost of the subframe and atleast a week to build
i think im looking at close to a grand but this seems to be the simple-est option and in the long run the most reliable, mitp 50 gets closer by the day
one think i will say i have sent 3 emails and got 3 replys within a single day, and Richard who i am dealing with knows his stuff
Edited by Brett on 22nd Aug, 2008. Yes i moved to the darkside |
i have been doing loads of research on different rwd subframes for the mini, my fav so far is the ring mini's rear mounted front subby, i saw a few good, rwd mini's at mitp last sunday witch seemed to be running mini style rear swing arms but with drive shafts, i cannot find any info on them at all, im confident in my building/ fabricating skills but not confident to build a complete rear subby and suspension geometry aswell, so im looking into some thing that can mount to say a rear beam conversion
h
