| Home > Help Needed / General Tech Chat > Some Help Needed :) | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
23rd Aug, 2008 at 07:40:59pm
Got the carb back on the car today.
Shit Happen's |
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
23rd Aug, 2008 at 07:57:06pm
Have you got thr fuel supply connected to the carb correctly? I once piped it to the anti run on by mistake and filled the carb and inlet and plenum with fuel.
23rd Aug, 2008 at 08:59:36pm
On 23rd Aug, 2008 shane said:
Have you got thr fuel supply connected to the carb correctly? I once piped it to the anti run on by mistake and filled the carb and inlet and plenum with fuel. Shane Dont think so. can't check now as it's locked up. But did yours still start by doing what you did ? Cheers Shit Happen's |
23rd Aug, 2008 at 09:23:06pm
Have you got the fuel pressure set right? Is the float set right in the carb?
23rd Aug, 2008 at 11:42:11pm
On 23rd Aug, 2008 Tom Fenton said:
Have you got the fuel pressure set right? Is the float set right in the carb? I could check. i've never looked at this before. You could be right, as ive just went down to have a look. And there is also fuel coming from the gasket on the carb side. I know how to adjust the fuel pressure. But i dont have one of those Gunsons Lo Gauge Vacuum Testers. Could i do the same with my boost gauge, which is a psi gauge ? It's a spare one :) If so. what can i do about keeping my fuel pump running. As before i put my new fuel pump in. it would run straight of the ignition. but this one only comes on ones the cars turning over for few seconds. hmmm, guess i could get the missus to keep turn it over (with out it starting of course) while im checking the pressure.? This is where i have the fuel connected to, so i know that's right. The other ones blocked. Mr Flanigan's old carb.. Look how clean i made it mate lol
Anyway. so do you have to set the float up in some way then ? I've built a good few carbs now,and all i've done is assemble them no problems. Cheers Tom :)
Shit Happen's |
17 Posts Member #: 3513 Member Stafford |
23rd Aug, 2008 at 11:43:39pm
Not sure if this relates, but I have a vague recollection of a similar problem. It was to do with the rebuild kit having a duff gasket between the carb and plenum. Not all the holes were punched out, and this caused the problem you describe. Bear in mind this happened about 8 or 9 years ago, I might be barking uo the wrong tree! Worth a check though? Philtune |
23rd Aug, 2008 at 11:52:50pm
Also just remembered this happens when the fuel overflows in the chamber - I don't recall having to set up the float, but the smallest amount of crap in the needle valve can cause this. Is the float free to move - or is it pinched? Philtune. |
