Home > Wanted > Someone with a mill to mod the back of a rocker cover for me please.
Hi
The rear of my mg metro rocker cover doesn't quite clear the back of the rockers and I was wondering if someone could just run a mill along the full height of the inside of the cover to make the clearence.
Obviously fluttering pieces of paper and a pint can be exchanged for this service.
Thanks
James
Edited by minimole23 on 24th Aug, 2008.
Have you tried putting the bolts in loose and then shoving it right back before nipping them down? This usually works.
You could easily acheve the same with an air grinder.
Yep, just grind it away with a carbide where needed.
