| Home > Help Needed / General Tech Chat > turbo diesel tuning | |||||||
162 Posts Member #: 228 Advanced Member |
16th Aug, 2004 at 09:53:22pm
im about to gain a mondeo turbo diesel for chuff all, can i increase the boost as i would with a petrol, i.e, stick a bleed valve on or do they work on different principles?? |
126 Posts Member #: 244 Advanced Member |
16th Aug, 2004 at 10:00:17pm
I believe that they need a proper tuning, a mate of mine put a bleed valve on a 2.0 TD asta van, it ran like a bag of the preverbial, Injection needs modifying Speedster turbo under construction |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
16th Aug, 2004 at 10:14:52pm
wind the diesel screw on the pump out, and then yes you can fit a bleed valve, youll be amazed what a difference winding the screw out will do, you may find its not worth increasing the boost..... who am i kidding... best do both! And on the 7th day........... God created turbochargers! |
16th Aug, 2004 at 10:16:27pm
i will see what its like when i get it, might not bother if its running ok, it will probably kill it, but hey, what the hell, it aint cost me nothing!
17th Aug, 2004 at 08:02:18am
It depends what engine it has!
AlexF |
17th Aug, 2004 at 09:20:53am
if it has a mechanical injection pump then like sparky says wind the pump up a bit and bleed some boost off the wastegate regulator......not guaranteeing it will last forever but have heard of a bloke with a 306 dturbo running something stupid like 2 bar of boost........
17th Aug, 2004 at 10:37:58am
down side with that is you will fail the mot on smoke!
AlexF |
17th Aug, 2004 at 01:25:44pm
not if you wind the pump back in before you give it to them!! only takes two minutes, so no problem really. the best way to do it to be honest, is to wind the pump out, till you are getting a bit of black smoke, then wind it back till its just dissapearing. hardly an exact science, granted, but its worked for a least three different vehicles i know of!
17th Aug, 2004 at 10:12:35pm
well, picked it up tonight and the boost is leaking off somewhere, split pipe or pipe come off, can hear it when foot is down, also clutch is goosed, other than that its pretty good for a free car lol, moted and taxed til nov!
18th Aug, 2004 at 08:17:24am
lol thats probably just the turbo screaming! lol
AlexF |
