Home > Help Needed / General Tech Chat > twin hif44 carb turbo setup
eskynation
Member #: 3490
new zealand. land of the kiwi bird
ive had this mad idea rushing through my head lol. what sought of fuel pressure and setup would i need to make it run. i was think 8psi at idle and 8psi above boost.. any ideas... will prob use cutom plenum when i do get around to doing it...
yes your right...
......its a mad idea, although im sure someone on minifinity will have an answer for this one
Jay#2
Member #: 648
Northern Ireland (ex AUS)
What's the advantage? People have seen 200-300+ bananas with the good old fashioned single HIF.
On 7th Nov, 2008 Nic said:
naeJ
m
you mean,the side float versions yeah?
eskynation
Member #: 3490
no a custom manifold with twin hif44 turbo carbss.
Ben H
Member #: 184
Melton Mowbray, Pie Country
As already asked, why do you want to do this?
However to answer the question, just because you have two carbs it doesn't mean that the pressure requirement of each carb has changed. Therefore the normal 3psi settings will still apply. Also just because you are using two carbs you will not be using twice the fuel so the flow rat required will not change either.
http://www.twin-turbo.co.uk
