| Home > Help Needed / General Tech Chat > Dizzy Module Problems | |||||||
![]() 46 Posts Member #: 278 Member Petersfield, Hampshire |
17th Aug, 2004 at 12:51:50pm
I have a 59 DM4 dizzy waiting to go on the car. As far as i'm aware this is an early turbo model, only problem is it has a seperate amplifier module thats mounted on the bonnet locking platform of the metro. No suppliers i've contacted even know what i'm talking about and after much searching through my Rover parts CD, found that the maestro used a 59 DM4 also, although i assume with different vacuum unit and weights/springs. Only thing is Rover want to charge me a handsome ?150 excluding vat for the module alone! |
17th Aug, 2004 at 12:54:48pm
The units are about £40 for a genuine lucas one straight from the lucas dealer. I asked a while back as i have a trade account there.
17th Aug, 2004 at 01:12:10pm
Yes you are correct in what you say about the earlier cars using a different distributor with a seperate ignition module. From memory they are mounted on a fair sized heatsink which is mounted on the slam panel or somewhere nearby anyway.
17th Aug, 2004 at 02:22:51pm
I can test the unit if your insterested...
AlexF |
17th Aug, 2004 at 04:04:10pm
yep mk1 is remotely mounted amplifier
