Home > Help Needed / General Tech Chat > Fuel problem
Giancooper
Member #: 2402
I read a lot in this forum, and I learned a lot thanks to you, now I have a problem that I can not solve and only you can help ....
I have one hiff n/a turbed whit an su kit, but when i start the engine the fuel don't go from the float (this is full of fuel) to the needle tube(sorry but I don't know the name in english)
I have the metro plenum and the turbo fuel regulatore...
all the pipe of the carbe is close...
someone can help me?
Edited by Giancooper on 28th Aug, 2008.
It could pay to strip the carb down and either rebuild it or clean it up if you cant get hold of a rebuild kit.
is it a turbo carb or a N/a carb? you say both about but im putting that down to your english (which is impressive by the way im sure i wouldnt be able to speak your language!) and not your inteligence/ability.
Giancooper
Member #: 2402
Sorry, I have an n/a carb sealed rebuild whit a turbo kit...
does the gasket between the carb and plenum have the extra hole thats lets the turbo pressure the float chamber?
if so is it the right way round?
Giancooper
Member #: 2402
I tried to start the engine without plenum and nothing
is fuel getting to the carb? what fuel pressure are you getting?
Giancooper
Member #: 2402
I can't set the pressure of the regulator if the engine don't start
Markie_D
Member #: 1660
Formally Mini_Uk
London
You can test the fuel pressure with just the fuel pump running *tongue*
Just turn the ignition on, and use a Lo - Gauge Compression Tester.
Shit Happen's
Turbo Shed
Member #: 30
Epsom, Surrey
in his first post it says there is fuel in the float chamber but not at the needle tube. mixture screw need adjusting? wrong needle? also could still be lack of fuel pressure? also if you cant work out whats wrong, was it rebuilt correctly?
Checked this?
Maybe the tee-piece trick is needed here?
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2103
Do you have an electric fuel pump?
Giancooper
Member #: 2402
Yes, I have a wron fuel pamp, facet solid state, but is just to start first time my engine....
I do not think that the Facet pump will provide enough pressure for the turbo fuel pressure regulator to work correctly.
You will need to get a high pressure pump.
If you just want to start the engine, then remove the turbo fuel regulator and connect the output of the Facet pump direct to carburetor.
The Facet pump is self regulating, so should alow you to run engine on idle.
