Home > Help Needed / General Tech Chat > Hose clips
Does anyone know who sells hose clips? NOT jubilee clips, but the ones that have a nut and bolt to clamp them up, if someone knows the correct name for them it may help aswell. Lol
Everywhere I search just comes up with jubilees! I need some around 45mm? *oh well*
Matt
For intercooler hoses? Search for Mikalor clamps. Dear, but good.
Cheers Tom, yeah there for my inlet stubs. Jubilees are to big and don't seem to clamp evenly like the other type. I'll have another search.
Mikalor - dear but can be got at a reasonable price off eBay - beware of imatations though, some eBay sellers use words like "Mikalor style...."
try LMA?
mikalors look sex though
I know what these are for *wink*
Try these, they are only 8mm bands, so narrower than others *wink*
Other option is phone Motorworks and order 8 new inlet rubber clips from them
Whoopsie, linky *happy*
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:MEWA:IT&ih=022
Edited by Sprocket on 29th Aug, 2008.
If you are indeed talking about the inlet stacks / injector holders on a K-head, we ran into the problem on Jims. The narrow jubilee imitators sucked, so we just used quality Jubilees, but notched the clip itself to clear the boss aropund the injector, which allowed it to fit much better.
The problem then was the tight turn radius of the silicon hose.
I'd definately recomend using a decent hose clip, but notching it to allow it to sit in a location such that it can do its job better.
id make some big straps to go round the plinenium and bolt them to the head ! *happy*
cable ties and gaffer tape? lol
Mikalor are dung IMO.
Pressure test your system and see. The bands are far too thick, and there is large step at the overlap, where the pipes can, and do leak.
Get proper thin banded stainless T-bolt clamps.
Although on the small diam pipes on a mini, and relatively low boosts involved....good quality stainless hose clamps will work fine..
Or there are modern variations around that same theme. Do ensure all pipework has some form of retention bead.
Sam
Member #: 1686
Oxford
i might put one of these on the return for the rad eg where the bottom hose would normally go onto the back of the block..
it keeps blowing off thier, done it with 2 hoses.
OMG Robert that's a big one
Yeah the stub are about 5mm to short to get a jubilee on and behind the beading on the stub! *oh well*
I like the idea of notching the clips may give that a go, cheers!
http://www.owendevelopments.co.uk/products...il.asp?prodId=2
HUBBAHUBBA
Member #: 10951
Anybody know of Mikalor (or type) that are quite slim (about 15mm wide) for 50mm hose? Cheers
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
T bolt clamps they are called in aus or boost hose clamps same difference most shops know what your on about...
Matt
For small diameter hoses like that, just use a good quality stainless jubilee type clip.
The T-Bold style would only really be needed for very high boost applications, and if the base metal you're clamping around is strong enough to support them. I've seen people destroy aluminium, and even stainless pipes from overtightening T-Bolt clamps.
And unless you can get the thin banded T-Bolt clamps, dont bother, the big thick bulky ones like Mikalor sell are crap and for huge industrial hose or exhausts
ie, these with the separate and thick/bulky overlap are shit and rarely seal properly. Great for exhausts though
http://www.spareco.com.au/documents/catego...BOLT_CLAMPS.jpg
These with the very thin band and overlap work great, if of course they are needed in the first place, which on a 45mm hose...no way would they be unless pushing 50-60psi or there are issues like no beading on the metal pipes etc
http://perrinperformance.com/images/M74510669.jpg
