Home > Help Needed / General Tech Chat > straight cut drops noise
mark4765
Member #: 249
mine are there noiseist when i decellerate by dropping a gear when slowing down...is this normal...what are other peoples experiences with straight cut drops regarding noise
regards mark
Edited by mark4765 on 19th Aug, 2004.
Mirage
Member #: 119
noisy !
T3Tone
Member #: 252
Sunny suffolk
Noisy and chatter at tick over with most people telling me it sounds fu*ked!!!
Which it does.
-MINI CLUBMAN 1380 TURBO-
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
people coming up in car parks and telling you your gearbox is about to blow up!! Usually its an old man *happy*
a;ex
AlexF
mark4765
Member #: 249
a;ex
lol,when i pulled in for the mot yesterday,the tester said 'i think you need a new gearbox mate'
i thought with only straight cut drops the noise wouldnt be to bad..must be very noisy with a straight cut gearbox aswell
regards mark
speedster turbo
Member #: 244
sounds great!! Mini/metro's whine in 1st gear anyway, granted not as loud as s/c drops. Personally I wouldn't have it any other way.
Speedster turbo under construction
T3Tone
Member #: 252
Sunny suffolk
Its the drops that make most of the noise mark, so fitting straight cuts gears in the gearbox would'nt make alot more noise.
turbo hogster
Member #: 178
stowmaket suffolk
i do love that sound plus all the birds allways look when i come for a gary throught the town center.
and when hot they will chatter like your teeth at minus 80 deg c lol.
LOL it can get a little embarrassing at times as every one thinks "that mini fukced" cos of the nosie!
Personally I love the noise of s/c drops and would fit them to my engine whether it needed them or not, just for the noise!!!
But so funny about usually an old man comes rushing over and tells you to turn it off quick before it explodes! My other toy has a plate LSD in it that clanks like anything at low speed, that is always amusing to see the alarmed looks of peoples faces in Tesco car park....
T3Tone
Member #: 252
Sunny suffolk
I think they sound great winding up when coming on boost:)
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
I agree I have no stereo so I can listen them Noisey gears!
16V project underway
giallofly
Member #: 164
The Stig..
Newport Pagnell
Mark, dispite your noisey drops how is your new turbo mini going?
mark4765
Member #: 249
very well jon....passed mot straight through and just running in at the moment.it feels very strong and smooth so looking forward to finishing the running in process... only problems ive had are a leaky washer on oil banjo bolt and stainless steel window wipers flying over back of car when it started raining and i put them on!
regards mark
giallofly
Member #: 164
The Stig..
Newport Pagnell
replace the copper washer with a new/newer one and nip it right up!
That engine has all the right bits cam' head etc.
Is it intercooled? if so should be good for 20psi now and again but would recommend 12/14 for normal running.
see how it feels.
