Home > 998cc > 998 Tuning - 1.5:1 Rockers
shawsy
Member #: 2865
My current engine spec is a
std bore 998cc with flat top pistons,
12G295 head
Kent 276 cam
Hif 44 carb
Just wondering if I added 1.5:1 ratio roller rockers would I have a problem with valve to piston clearance, or would there be sufficient clearance retaining the 276 cam?
any help would be much appreciated.
Cheers, Jon
With respect, you would be waisting your time and money.
It's well documented somewhere that past a certain lift you will not see any gains. I'm sure that the 276 cam will provide as much lift as the 12G295 head will handle.
shane
Member #: 1246
Lowestoft, Suffolk.
Heed Pauls advise, I have built a couple of fast road engines using the 12g295 casting, and couldnt get any gains from anything more than the kent 266, I had gains from pocketing the block and fitting a 12g940 casting, achieved 65hp very revy lively motor.
Shane
the_soon_to_be
Member #: 1600
Portsmouth, Hampshire
just jumping in there, my +80 998 with flat tops, morspeed phase 3 cam and mg 12g940..
is it worth 1.5 rollers, going to be placing my order and these were an item, would i be wasting my money
gaz
did you read the posts inthis thread?
Ben H
Member #: 184
Melton Mowbray, Pie Country
I have to say that the second engine in this thread is quite a lot different to the first.
We have run +20 998s with 12G940 and 276 cams with and without 1.5 rockers and i have to say that it is better with. However with the same engine and the 295 head it was probably better without, but not by much.
edit to say: The engines were standard bottom ends that we rev to nearly 8k, we don't get many miles to the engine. these are not the same in any way to the 998 turbo motors we build.
Edited by Ben H on 2nd Oct, 2008.
http://www.twin-turbo.co.uk
the_soon_to_be
Member #: 1600
yes, he has 12g295 and i have a 12g940 head..
did you not read my post,
alpa
Member #: 2093
Grenoble, France
Don't forget the valve work is a lost work.
foot, mouth, insert.
in my defense it was late.....and im a bellend!
