| Home > Help Needed / General Tech Chat > why wont my car run! help | |||||||
20th Aug, 2004 at 01:41:19am
finally my car is working but it fires then dies, the fuel pump works and fuel is reaching the carb i think it could be an air leak, the hose to the carb from the regulator is held on by one of those shit clips with 3 prongs is this enough? i can actually rev the car but only if i keep turning the key to pos 3 and flooring it, the exhaust didnt half bloody pop thogh! any ideas could it be cos i have no anti run on valve etc |
20th Aug, 2004 at 01:53:32am
sorry forgot to mention the hose from the actuator is also blocked off where it went to that pressure reducin valve thing should i plumb it in, also can i incrrease boost just by buying a different actuator? any help greatly appreciated |
20th Aug, 2004 at 01:57:54pm
sounds like some sort of electrical fault if you have to keep turning key to position 3
Edited by Tom Fenton on 20th Aug, 2004.
63 Posts Member #: 325 Advanced Member |
21st Aug, 2004 at 11:05:31am
Check that you have power at the coil when the ignition is on position 2, if not there is a wiring fault.
Edited by killer_chiller on 21st Aug, 2004. |
22nd Aug, 2004 at 12:25:55am
cheers guys will try those things tomorow, the pump should stay on pos 2 after starting but not before correct? |
22nd Aug, 2004 at 06:12:07pm
Make sure your leads are in the right order because you might be misfiring and this will cause the zorst to pop |
583 Posts Member #: 233 Post Whore Beugen, Netherlands |
22nd Aug, 2004 at 08:09:04pm
t2clubby, got your point now, go play barbies now.
22nd Aug, 2004 at 09:48:08pm
wtf you talkin about arno |
22nd Aug, 2004 at 10:09:35pm
gobshite |
22nd Aug, 2004 at 10:18:04pm
T2clubby, just kidding, take it easy.
22nd Aug, 2004 at 10:19:57pm
Fair enough ... i hadnt read that post..
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
22nd Aug, 2004 at 10:21:10pm
hey guys chill out ..... take a drag on this .... TurboLessTosser |
22nd Aug, 2004 at 10:29:56pm
could take a beer as well :cool:
23rd Aug, 2004 at 09:09:18am
It's ok I'm calm now............ :p
