Home > Wanted > distribuator
mettyturbo
Member #: 344
The Royal Mail lose every parcel I ever send.....and I am a TWAT
i need a dizzy but 1 that has got three pins in the little black box on the side can you help
nutter driver
Member #: 47
Not very sunny swanage
i have got one, but youre not having it! seriously though the ignition modules, (the black box) are interchangable, ie you can swap the two pin for the three pin ones easily. hope that helps a little bit.
Pete
mettyturbo
Member #: 344
what would happen if i put it on with 2 pins would it make my car run but cut out after any length of time cause thats what its doing think it might have sumin to do with dizzy
nutter driver
Member #: 47
two things, firstly, in my experience, either the little buggers work or dont, there is no inbetween, the couple ive had that stopped working just died, dint start cutting out, then working again like yours seems to be.
secondly, and more importanly, i looked at my dizzy with the three pin black box, and despite there being three pins, the connector that goes onto it only uses two of them.
try chucking this in the help needed section, i cant help but think it might be something other than the module causing your problem. i cant be sure, (obviously :) ), but like i say, im my experience the black boxes either work or dont.
hth,
Pete
