| Home > Help Needed / General Tech Chat > lifting the engine. | |||||||
![]() 1014 Posts Member #: 238 Post Whore essex |
21st Aug, 2004 at 11:18:23am
how does everyone lift their engines? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
969 Posts Member #: 47 Post Whore Not very sunny swanage |
21st Aug, 2004 at 01:15:10pm
ive changed about six or sevn engines, always using the brackets that bolt to the rocker cover studs. they were supplied as standard on A35's so afaik they are perfectly ok to use, never had any problems....
And on the 7th day........... God created turbochargers! |
23rd Aug, 2004 at 12:10:33am
i used a proper engine bracket which goes on one of the studs, and i've used one method where you bolt it to the manifold stud and a head stud on the opposite side diagonally this works really well just remember to take off all the ancillaries! |
23rd Aug, 2004 at 03:01:25am
i just use a bit of rope looped round the water pump and round the little brackety bit for the top engine steady. don't even use a proper crane though, just one of them things you get in hospital for lifting fat dudes out of the bath an stuff. On 20th Oct, 2015 Tom Fenton said:
23rd Aug, 2004 at 11:41:55am
I've got a engine crane, but its usually at the back of the workshop. I eat a bananna the lift it in Team www.sheepspeed.com Racing
63 Posts Member #: 325 Advanced Member |
23rd Aug, 2004 at 08:25:42pm
Fence post, padding and lots of noise! |
![]() 439 Posts Member #: 176 Pre-op Transvestite Felixstowe, Suffolk |
24th Aug, 2004 at 11:53:52am
i normally use the bar from my weightlifting bench, loop rope round that and round the engine. Then have me crouching one end and a pal on the other end with the bar resting on our shoulders, then stand up. Probs not too good for the old back if you do it too often tho. NO LONGER A <3 lover of BOLT-ON plastic <3 .... (and DOUBLE proud of it) |
24th Aug, 2004 at 12:07:36pm
I take the roker cover off, put my little finger around the rocker shaft and simply lift it in...
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
24th Aug, 2004 at 03:39:21pm
I use a hoist , with two seat belts through the hook
TurboLessTosser |
24th Aug, 2004 at 04:42:20pm
24th Aug, 2004 at 08:00:56pm
cheers for the advice!
126 Posts Member #: 244 Advanced Member |
24th Aug, 2004 at 08:20:18pm
I pay some dude to do it for me - don't even get my pinky dirty (TD)!
Speedster turbo under construction |
