Home > Help Needed / General Tech Chat > Long shot
andygardner
Member #: 513
Sheffield
The link is an audio clip of a standard metro turbo unit idling.
http://media.putfile.com/mini-32
I've got timing set at 7degrees and think mixture is in the right ballpark (colortune *oh well* and checking plug condition). It *seems* to be running alright, revs up freely etc, although it's not been put under any load. Does it sound a bit too 'tappy' though?
I've set valve clearances as per haynes but it doesn't seem to have made much difference. Tried the screwdriver in the ear trick but can't really hear anything beyond what you can hear in the clip amplified.
Am I just being paranoid and crack on towards mot see how it goes or should I be thinking about pulling the engine and stripping it down for inspection?
Edited by andygardner on 19th Sep, 2008.
How hot have you got it? When you get it properly hot it should quieten down.
andygardner
Member #: 513
Sheffield
Hmmm thats a good point the clip there was from cold.
The other day when I was tinkering in earnest I'd had it running a while so it was up to temp. It wasn't till next day I thought it sounded a bit noisy.
I'll warm it up tomorrow a see if it quietens down.
PaulH
Member #: 2340
Dublin Ireland
sounds tipical of an A series engine with 50 - 60k as TD says when its hot it will quiten
has this a std cam or moded ??
On 17th Feb, 2009 Rob H said:
andygardner
Member #: 513
Sheffield
I've assumed its standard metro as thats what I was told when I got it. Thats the problem working on assumptions though could be anything for all I know.
PaulH
Member #: 2340
Dublin Ireland
ya some of the Morspeed cams and some of Swiftys cams can be quite tappity when there cold as the have a very Quick opening speed which gives the sort of sound that is coming from you motor. I had a problam with a 1380 once which sounded tapity and the cause was a bent push rod which caused a bit of valve lag and made quite a racket.
regards,
Paul.
Mech fuel pumps are tappety when idling
philtune
Member #: 3513
Stafford
Had a listen - as suggested, get it up to temperature and see if if quietens down. Things to check, re-adjust tappets, check the pushrods are not binding in the block or head, check to see if the rockers lock nuts are not clipping the pillars. If the rockers have heavily worn pads then getting the clearance right is impossible - try swapping to an alternative set to eliminate them as the source. This approach will also eliminate severly worn rocker holes - there are no bushes in A+ rockers. Can't think of anything else at the moment. Good luck. Philtune
andygardner
Member #: 513
Sheffield
Had a listen today, it does sound a little better once it's warmed up but still quite tappy. As suggested it's probably just a little tired and nothing serious, I'll go over the valvetrain and see if anything presents itself.
I've got my old n/a 1275 sat in the corner of the garage is the rocker assembly same as on the turbo?
yep same assy,
when you pull them off have a look at the rocker shaft, if its worn that could be the problem.
yep same assy,
oops!
Edited by Joe C on 20th Sep, 2008.
