| Home > Help Needed / General Tech Chat > Thermostat and radiators | |||||||
23rd Aug, 2004 at 01:44:54pm
As many of you know, I've bought Mark's old car. The trip to Norway went OK apart form SC drops and 500miles on the road. Edited by Vegard on 23rd Aug, 2004. On 13th Jul, 2012 Ben H said:
23rd Aug, 2004 at 03:12:41pm
I run a side mounted rad, I've always had cooling problems Team www.sheepspeed.com Racing
23rd Aug, 2004 at 04:11:32pm
side rad, no cooling problems but only 120bhp.
AlexF |
23rd Aug, 2004 at 04:31:40pm
I think vegard is the problem that your not running a lot of boost at the moment, Mark always run at least 15psi, am I right in thinking your running around 8 psi? Just stick a thermostat in and you'll be fine Team www.sheepspeed.com Racing
421 Posts Member #: 245 Senior Member |
23rd Aug, 2004 at 09:21:50pm
86 stat,front rad, |
24th Aug, 2004 at 12:02:41pm
As i understand, you're going to be replacing the front end???
25th Aug, 2004 at 09:54:49pm
I haven't decided on whether to change the fron, and even if i do, it will be with a Curley F/G one. That leaves planty of room for stuff in the front compared to a steel one. This I'll manage, but thank you for tips Dave.
26th Aug, 2004 at 06:41:00am
Vegard, I have used a cold thermostat, 70 something degree all the time. I have the same one fitted to Minor as well. I don´t have the bypass hose between the head and water pump, instead I have drilled the thermostat like Dave to allow some by-pass.
26th Aug, 2004 at 10:49:25pm
Hi Jukka, yes to that mate.
27th Aug, 2004 at 06:44:15am
I take the head off every 5 years. I am running a 1380 engine at 15 psi. |
28th Aug, 2004 at 06:06:08pm
what you mean Jukka? Best 1/4 mile 13.2 seconds @116 mph
30th Aug, 2004 at 08:37:25am
i do the same as willie, dont put holes in thermostat as the engines will take longer to heat up as long as there is curculation round the head and block via the heater tap it will be fine.
1st Sep, 2004 at 01:07:39am
No I do the same as The Hogmister! as you told me and i thought what a good idea!:) Best 1/4 mile 13.2 seconds @116 mph
![]() 198 Posts Member #: 345 Advanced Member Guildford Surrey |
2nd Sep, 2004 at 09:35:46pm
Just to let you know, we had made the 2 core made with 21 tubes and D type finning not 19 tubes and B type fining as others have. More expensive to make but far superior in cooling terms. The o/e rad under grd110 pt number is a great rad as fitted as standard to the later Mini 30's these are the 3 core as you mention with D type finning. Ian |
6th Sep, 2004 at 07:00:58am
Miniwilliams,
6th Sep, 2004 at 09:02:51am
hi jukka
6th Sep, 2004 at 10:06:58am
I use the silver TAM1521 with ARP hardware. I torqued the head to 50 lbft and did not retorque afterwards. I have 36 mm intakes and 31 mm exhaust valves that have been offset. The ports are modifies, most of the guide bosses are removed. The ports are not that big, I tend to be conservative with porting. I suppose there is still something gained if going to larger ports. |
6th Sep, 2004 at 02:24:19pm
Has anyone used a 4 core rad with a turbo motor? That was my plan for the main reason that I have a brand new 4 core, the thinking being that the extra water capacity would help?
