Home > For Sale > Jack Knight Box Invelute
AV-R Technologies
Member #: 345
Guildford Surrey
Jack Knight Invelute dog box with Mk 5/6 clutch plate LSD ex Turbo challenge for sale
complete with 3.9 semi helical crown wheel and pinion,central oil pick up ready to go.
All good nick £1295.00 INC VAT AND CARRIAGE. also loads of specialist tools just ask,
http://www.avonbar.com
turbo22
Member #: 3684
wisborough green west sussex
any engines?
minimark
Member #: 19
newcastle
what specialist tools are included in the price??
Scruffy
Member #: 328
Seaford Rise, South Australia
An imitation Kevin Keegan comforter you mad geordie cabbie!!! LOL
On 5th Sep, 2011 Vegard said:
Sam
Member #: 1686
Oxford
Why did this pop up when i just brought my crank...
bugger now skint once more.
OMG Robert that's a big one
If it popped up when you brought your crank I guess you would have seen it...
I might be interested in this.
What sort of torque rating would this box have?
Would it handle the power from a 200+hp 1293?
Is it close or standard ratios?
Edited by Paul S on 24th Sep, 2008.
I now realise after a bit of research that this is a silly question.
They are either close or ultra close.
Either way, I don't think that it will suit our strip warrior.
I think it would be perfrct paul
Even with a 2.31 first gear and a 3.1 or 3.4 diff.
The 3.9 would be too low for top end speed.
AV-R Technologies
Member #: 345
Guildford Surrey
At that price all you need do is buy a new crown wheel and pinion and you would still be quids in!!.Not ultra close, but is as we used on the challenge cars.
AV-R Technologies
Member #: 345
Guildford Surrey
Yes cheque is alright call me 01279-873428 and I will send it up by carrier.I found a spare new set of collets to go with the grinder.Lucky you.
Only 3 s/h engines and heads suitable for exchange or re-building.
AV-R Technologies
Member #: 345
Guildford Surrey
If your engine pulls a true 8500 that is 124 mph + depending on tyre size!
AV-R Technologies
Member #: 345
Guildford Surrey
and I used a 3.9 for sprints at Goodwood and I still hold the standing lap record so how fast do you think you will go??
I'm expecting peak hp at 6500rpm from a turbo 5 port. So a 3.44 diff would be better. I'll just check that I can get an LSD crown wheel and pinion in that ratio or close.
EDIT: 3.46:1 available from Minispeed at £270 gulp.
Also found that one guy on here found the 3.9 limiting on quarter miles.
Edited by Paul S on 25th Sep, 2008.
Quarter miles and circuit racing are two different kettles of fish.
AV-R Technologies
Member #: 345
Guildford Surrey
Hmmm Yes I see the dilemma.Our Turbo cars would run almost 9k on Silverstone GP circuit.a 3.9 or 4.1 should be spot on for 1/4
AV-R Technologies
Member #: 345
Guildford Surrey
just a point of interest we used to use a 4.3 with 1.04 drops for the Brands Hatch short circuit to do low 52 sec a lap in my old S. and that was in 1979/1980!!
The car we are building is primarily for drag racing, although it will also go round corners.
Gearing is critical to get the car off the line quick and through the traps at maximum bhp.
To match peak power to the expected terminal speed of 110-120mph you need a 3.4 diff.
A 3.4 diff and a 2.31 first gear on a low CR high boost turbo is going to bog off the line.
This is a great gearbox for circuit racing, no doubt, but I think I'm better off building up a box using a clubman gear set and an ATB LSD.
I've got 2.31 1st, 3.44 diff, and my car never bogs off the line,
HaHa, I thought that may be a controversial statement.
But are your 60fts any good?
2.2 is my best on road tyres, not the best, but not bad
i'm guessing it was me that you found was limited by the 3.9 drag racing?!
basically, yeah i was on the rev limiter before i finished the quarter at 7k i think it was, and thats 100mph on 10's. rough and mean anyway.
I'm thinking though it will be perfect for a hillclimb but i could of done with longer legs for the 1/4 mile.
and that was with garbage 60ft's... 3s or higher!
Not bad? That's as good as any on here.
Decisions decisions decisions. £1500 ish including the 3.4 diff.
