Home > General Chat > Moggy minor engines into midgets
I'm after a spare block for the midget and found this
http://cgi.ebay.co.uk/Morris-minor-engine_...id=p3286.c0.m14
i assume it will be the same block casting as a midget?
Cant go wrong for £30 and its local to me.
Probably be sold mind by the time i get an answer, nobody go poaching it from me!!! *happy*
Yes, but Minors were never bigger than 948cc. Aka Junk!
ah, bugger. thought that was a 1275?
right so basically i want a cheap 1275 block as a spare for the midget.
what are my options?
steve1275
Member #: 951
Bromsgrove
Go on the midget and sprite club site classifieds.Also Marina a+ block will fit.
'Where does the engine go?'
Most Minors except the early ones were 1098cc. 1963 onwards according to Viz.
Vegard is not always right *happy*
Inline 1275s were fitted to Marinas I believe.
Edited by Paul S on 29th Sep, 2008.
Were they? I thought not.
I've ownded a Marina 1300. Rolled it on my dad's field. Quality!
Montego 1300?
steve, any links to the good ones?
The Maestro (is that spelt right?) 1300 had the A series engine but with an end-on (rather than in the sump) front wheel drive gearbox (like modern front wheel drive cars) so may well also be the "in-line" version of the engine.
If that makes sense ???
not sure abount the montego/maestro units - I know they used a VW gearbox - not sure if the bell housing would be the same?
Marina/ Itals are a constant source of engines and gearboxes for the Minor boys
steve1275
Member #: 951
Bromsgrove
Try http://www.mgcars.org.uk/midgetspriteclub.
tadge44
Member #: 2500
Buckinghamshire
1098 post 1962 is right.Marina/Ital engines will fit,but beware of possible oil filter clearance problems.I have also converted a Metro block to inline operation with a tuftrided Marina Crank etc.That block is available if you live close enough.PM me if interested.
whats involved in converting one?
I have mini blocks spare and if its mainly changing the crank then i would use the one coming out of the engine thats in. i could still get everything else built.
if its minor maching mods thats not a problem.
tadge44
Member #: 2500
Buckinghamshire
Main problem is in the rear main bearing area -you need an inline cap to take the sump seals OR modify the sump to suit.You do need to use a crank with a flange to attach the flywheel of course.While you are at it,take a look at the sealing arrangements for that rear main bearing and consider whether an aftermarket kit with a proper lip seal might be worthwhile.Also look at increasing the size and number of breathers,because,as you probably already know,rear main oil leakage is almost endemic with these motors.
tadge44
Member #: 2500
Buckinghamshire
I forgot -if you go the modified sump route you will need to modify the cap to allow oil to drain away from the rear main into the sump If you use the rear main cap from the inline engine it must be line bored to match the others.
Se7en
Member #: 446
Burntwood Staffordshire
Marina Van on ebay
http://cgi.ebay.co.uk/Austin-Morris-Marina...id=p3286.c0.m14
