| Home > General Chat > OT- Q for the engineers... 'flat' knurled finish? | |||||||
30th Sep, 2008 at 06:28:05pm
So I have a potential application where I need a steel plate that contacts an alloy surface, and is sheared against, and needs greater clamping pressure to generate the friction to stop relative movement than is available with the fasteners / thread depth available.
Edited by turbodave16v on 30th Sep, 2008. On 17th Nov, 2014 Tom Fenton said:
30th Sep, 2008 at 06:54:06pm
I think the rear camber brackets are serrated plate on serrated plate so the two positvely interlock with each other.
30th Sep, 2008 at 07:00:21pm
Found this...
30th Sep, 2008 at 07:43:55pm
It is a bodge,but you say you will never need to dismantle it again so what about Loctite -or deliberately set up some corrosion between the alloy and steel -you know how that binds them together ! Not an elegant solution but pragmatic, eh ?. |
30th Sep, 2008 at 08:24:53pm
hmmm,
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
30th Sep, 2008 at 08:40:05pm
maybe a heavy circular lay on the steel part would help clamp against the aluminum? |
1st Oct, 2008 at 04:04:14pm
Well, the part is internal to a trans so not an issue, and loctite is a no-no. We're looking at a cutter lay, but rolling a single serration rather than a full cross might be just as good (force is in same plane) and cheaper...
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
1st Oct, 2008 at 04:54:18pm
Old school shaping m/c with a course feed and a fine tool will give the desired surface finish. Better than a knurling roller in a mill anyway. |
1st Oct, 2008 at 05:38:18pm
Why not just use a bonding agent? AlexF |
12 Posts Member #: 1980 Member |
1st Oct, 2008 at 06:15:01pm
Bonding agents would be ok as long as they are able to withstand the heat of the oil warming up, and indeed the oils themselves - some oils will eat away at the bonding agent casing premature failure.
1st Oct, 2008 at 07:23:06pm
On 1st Oct, 2008 AlexF2003 said:
Why not just use a bonding agent? This isn't for something I'm working on at home - it's a work related problem that has come up in the last few days. Bonding agents are real no-nos for assembly and recyclability reasons. We've got a few potential soutions, all have pros and cons. On 17th Nov, 2014 Tom Fenton said:
1st Oct, 2008 at 07:31:24pm
On 1st Oct, 2008 Delboy_Trotter said:
Your best bet (on the cheap) will be to mount the plate on a mill and then tilt the head over to around 45 degrees and using a straight cutter, machine v grooves across the plate so you end up with the following across the plate :- vvvvvvvvv, which provided the tips are sharp enough should bit into the alloy. this is how the rover "r65U" final drive crown is mated to the differential, it is considered an upgrade for the "r65" bonded(and slight interference fit) setup thats normally used :) they still fail, but definately stronger than the bonded units :) turbo 16v k-series 11.9@118.9 :)
2nd Oct, 2008 at 08:38:38am
Arr I see - I was thinking of A-series parts LOL AlexF |
22nd Sep, 2015 at 02:56:34pm
Post resurrection. Im looking to do the same on something, mainly cosmetic rather than practical. But has anyone ever used one of these??
Edited by MikeRace on 22nd Sep, 2015. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
22nd Sep, 2015 at 05:20:30pm
to add to this, bmw suspension bolts have steel washers, when they mate to an aluminium surface the washers have 4 lightly raised ridges at 12,3,6 and 9 o'clock that dig into the aluminium and (i presume) greatly increase the load the joint can take in sheer turbo 16v k-series 11.9@118.9 :)
30th Sep, 2015 at 10:36:22pm
Can you coat the steel components? We make our own cutting tools and spray tungsten carbide onto the surface as a rough cutting face. Once it's on it has to be ground off and the finish is we get is like a 120grit finish so it will certainly dig into the surface it is clamped against. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
1st Oct, 2015 at 08:37:40am
Its purely to achieve the look on the trigger plate.
1st Oct, 2015 at 08:53:10am
The way I would make that would be to start with a flat oval plate, roll the "knurl" onto it, then press it to form the curve in the face.
1st Oct, 2015 at 09:13:47am
Yeah the curve isnt that important yet, how do I roll it on pal?? Would it be a miller? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
1st Oct, 2015 at 10:27:42am
Yes I would say that would be easiest, put a knurl tool in the vertical chuck somehow, press uit down on the plate then move the bed back and forth to roll the pattern into it.
1st Oct, 2015 at 10:38:15am
Nice one pal "CARRRLLLLL!" 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
