Home > Help Needed / General Tech Chat > Replacing Core Plugs
graemec
Member #: 1424
Carnforth, Lancs
When knocking new core plugs in, what sealant do you guys recommend - some loctite compound?
Star Mag
Member #: 375
Leicestershire
I havent had to do my minis engine but on engines at work we use a bit of paint, im sure some loctite flange sealer would be fine!
Sam
Member #: 1686
Oxford
dont, they are interference fit i belive.
knock them in with a socket and that is that.
althought if your worried i dont think some loctite would hurt.
OMG Robert that's a big one
Its upto you I would recommend using the blue gasket, mine were put in dry and they leaked for a while until the corrosion sealed them? They don't no more but they did at first.
Star Mag
Member #: 375
Leicestershire
Yeah they are interferance fit! sealer is the belt and braces approach! *happy*
PaulH
Member #: 2340
Dublin Ireland
I always use sem- setting Gasket compound Like hermitite when I put them in never hade a leak to date
On 17th Feb, 2009 Rob H said:
Loctite retainer, cant remember the number but there are only two common ones, high strength and low strength *wink*
If the factory used some sort of sealer, then i will also use it *tongue*
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I put them in dry.
On 19th Jan, 2010 wil_h said:
smirk!
On 3rd Oct, 2008 milamber said:
I put them in dry.
