Home > Technical Chat > Compression ratio calculator
1293GTT
Member #: 3141
Orkney (AKA The Rock)
Excel Compression ratio calculator i've made as i was having trouble finding one. Its not pretty but it works!
Keith
Mr Joshua
Member #: 1954
Luton Bedfordshire
Cant get this up but does it do dynamic compression ratio as well?
edit: Curse tab lock!!!
Second bite at the cherry and it came up |Question answered no it doesnt. Nice table!
Edited by Mr Joshua on 6th Oct, 2008.
Own the day
1293GTT
Member #: 3141
No just static compression.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Mine is a little more flexable...
http://www.afracing.com/CR.xls
AlexF
1293GTT
Member #: 3141
AlexF2003
Yeah your ones slightly more complex than my one.LOL !
I only created it as the link you posted in another topic kept taking me to a random page and not the file. guess it was mozilla that was causing that problem as its working now. Cheers for replying!
Keith
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
yours is good keith - simple to use :)
AlexF
Mr Joshua
Member #: 1954
Luton Bedfordshire
well add this one and you can tweak everything
http://www.rbracing-rsr.com/compression.htm
Own the day
ha, i like the 'eat shit' tab, classic!
Mr Joshua
Member #: 1954
Luton Bedfordshire
I know the yanks love putting that in had me in fits when I read it first. I also like the altitude function living in Luton I am at 462ft average never realised that before.
Own the day
the compression ratio calculator on this is erm either bad or im shit. just did what i plan to use and a few geusses it came up with 7.01:1 compression ratio. did the standard parts said on top right sposide 9.4:1 cr comes up at 9.7:1 instead...
Hmmm....
I have no problem with it, I downloaded the xls file to my laptop and have all my figures entered and every time I check a variation on any of the figures, the result is just what I would expect.
It's a bit fiddly as to which cells you enter, but works fine.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Whos?
AlexF
thimo
Member #: 710
Amsterdam, The Netherlands
Thanks Keith. After trying your Excel sheet I found out there was a big mistake in my own calculation. I calculated a compression of 9,85 where it should have been 10,85. Oops...
http://projects.ferrenzo.nl/
