| Home > Help Needed / General Tech Chat > smoking engine | |||||||
100 Posts Member #: 344 The Royal Mail lose every parcel I ever send.....and I am a TWAT |
27th Aug, 2004 at 09:00:04am
i have rebuilt my engine recently but it smokes really bad on start up it seems to be white smoke anyone have any ideas cheers lee |
27th Aug, 2004 at 09:17:00am
valve stem seals
AlexF |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
27th Aug, 2004 at 01:14:00pm
afaik if its white smoke, then it's supposed to be water. could be condensation, or could be something more sinister like a head gasket.
And on the 7th day........... God created turbochargers! |
126 Posts Member #: 244 Advanced Member |
27th Aug, 2004 at 10:05:09pm
I would go for condensation too, what does it smell of?
Speedster turbo under construction |
27th Aug, 2004 at 11:00:26pm
could be running too rich if the smoke is white |
28th Aug, 2004 at 08:39:15am
its not like a little bit of smoke its loads i start it up and it fills the garage completely then it chokes me to death im woried
28th Aug, 2004 at 10:03:21am
well generally speaking you have three types of smoke,
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
29th Aug, 2004 at 11:26:01am
Just another thought. If this engine has just been put in, could it be oil on hit surfaces such as exhaust, turbo etc. Could it be shit thats getting burnt of hot sufaces ???? |
29th Aug, 2004 at 06:49:54pm
white = oil too if theres lots of it, if you say mashed the springs in the oil controll rings.. turbo 16v k-series 11.9@118.9 :)
30th Aug, 2004 at 07:45:53am
sent my head away and had it rebuilt still smokes tho the turbo is new and im getting 170 on evry cylinder i dont know what it could be |
30th Aug, 2004 at 09:49:39am
ok then, another idea.....
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
30th Aug, 2004 at 04:09:20pm
mine was smoking very badly at idle
TurboLessTosser |
31st Aug, 2004 at 07:31:50pm
right lads the turbo i bought was new but had been stood about for about ten years so i think the seals have perished or summet another think is i took off my turbo and theres only oil in 1 branch of the exhaust manifold when i first got my car running i washed the bores with petrol bye mistake i put fuel pipe on wron g 1 but i still have good comp i just dont know |
31st Aug, 2004 at 10:44:46pm
if there's oil in one of the branches of the manifold i'd be checking out the rings and valve seals. which branch is it? the one off cylinder 4 by any chance?
1st Sep, 2004 at 05:41:03pm
yes cylinder 4 how did you know |
1st Sep, 2004 at 05:45:48pm
cylinder 4 is usually the culprit because it runs hotter than the others because of poor cooling.. time to check those rings mate......... |
![]() 213 Posts Member #: 249 Senior Member |
2nd Sep, 2004 at 06:36:42pm
quote 'when i first got my car running i washed the bores with petrol bye mistake i put fuel pipe on wron g 1 but i still have good comp i just dont know ' ................... i did this aswell and mine smoked badly....changed the petrol contaminated oil and it stopped Edited by mark4765 on 2nd Sep, 2004. |
3rd Sep, 2004 at 01:02:38am
(mental note to self - must change fuel contaminated oil) Speedster turbo under construction |
4th Sep, 2004 at 02:56:55pm
On 03/09/2004 01:02:38 speedster turbo said:
(mental note to self - must change fuel contaminated oil) it really made a massive difference on mine.....i was disapointed to see my newly rebuilt engine smoke continuosly and leak oil all around the sump.....i thought to myself that if lots of petrol had got in the oil from when i tried to start it initially with the petrol pipes the wrong way around, then the oil would be very thin and possibly getting past turbo seals or the rings or guides....when i drained it ,it was like piss water....put fresh oil of the same grade and make and it literally stopped smoking and leaking instantly
mark |
4th Sep, 2004 at 10:03:20pm
I know it needs doing, I was told when I bought the donor car I should change the oil even though it had been freshly re-built. Seemingly, even if you aren't driving the car and are just using the engine to move it in and out of the garage (VERY short trips) it is wise to change the oil before using the engine properly as these engines are renowned for getting fuel contamination in the oil. Sure enough, even before I kinked the fuel return and flooded the engine, the oil stank of fuel.
![]() 198 Posts Member #: 345 Advanced Member Guildford Surrey |
7th Sep, 2004 at 01:49:05pm
Generally white smoke on power IS the Turbo unit.
146 Posts Member #: 350 Turboing minis since '89<br> Supercharging minis since '04 |
7th Sep, 2004 at 09:42:52pm
have to disagree there (ian?), ok maybe a diference of opinion , i would say first sign of the turbo on its way out is continuous blue smoking on idle , valves guides are usually blue smoke on start up and or overrun , worn bores blue smoke under load and crank case pressure from breathers
![]() 2641 Posts Member #: 19 Post Whore newcastle |
7th Sep, 2004 at 09:55:55pm
learning fast .lol. Everyone knows that instructions only have to be read if the thing doesn't work....
