Home > Wanted > Need an LSD CWP - 3.44, 3.65. 3.76
jasper234
Member #: 3974
Need a SC CWP - 3.44, 3.65 (ideally) or 3.76 for a tran-x slipper. Good nick, no pitting, usual stuff.
Ta
jasper234
Member #: 3974
by he way, have a 4.1 that I could swap you for if that helps.....
I think you'll find that the highest you can buy of the shelf is 3.76.
3.44 in the twinnie from MSC
Edited by fastcarl on 3rd Nov, 2008.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Vegard is WRONG :)
On 4th Nov, 2008 miniminor63 said:
Vegard is WRONG :)
SHOCK HORROR!!!!!!
Is this something new? After all it was a question of diameter.
miniminor63
Member #: 672
Oslo, Norway
3.44:1 has always been available
No, I don't believe you. I was after one four years ago but NO.
miniminor63
Member #: 672
Oslo, Norway
oh well, your loss:)
they were in minispares cataloge in 2000
Hedgemonkey
Member #: 360
Vegard is right. An SC CWP is 3.7 only.
Matey on ebay does a SC 3.44
The others are semi-helical from anyone else.
Following an old conversation, SC wear out mega fast, too fast to consider for even a weekender, IIRC. They are also impossible to set up the lash, which seems half the problem.
Can anyone back this up.
I'm after a 3.7 Semi LSD crownwheel. Will buy a new pinion, as they're invariably shot.
jasper234
Member #: 3974
Anyhow, I still have a 4.1 straight cut CWP, and just to really set you off a 4.2 straight cut CWP, one of which is fitted to a Tran-X LSD in an MBE sequential gearbox in my Mk2 cooper.
SO, just to settle your arguement, you CAN buy a 4.1 and a 4.2 SC CWP.
Back to the start.....happy with SC or semi hel - as long as both gears are mint, and ideally a 3.6. The 4.2 is giving me a headache.......
Hedgemonkey
Member #: 360
We are talking new SC crownwheels here. Minispares do a 3.7 and the rest are semi-helical. Unless you are getting Mr Gear Cutter to do specials.
A couple of years ago, this was the case.
