Home > For Sale > KAD 5 Speed Dog 'box
graemec
Member #: 1424
Carnforth, Lancs
Not mine so not put it into For Sale, but thought this might interest some of you:
http://www.theminiforum.co.uk/forums/index...howtopic=101083
Yeah I saw this...seems quite cheap?
yes looks good untill i saw the 5th gear ratio, i'll be sticking with my 4th for now, NO point in having a 1.1 5th gear for the road IMO!
Scruffy
Member #: 328
Seaford Rise, South Australia
Why not? Fit a 2.7 and should be fine - whats the first gear ratio?
On 5th Sep, 2011 Vegard said:
kads are 2.5 firsts IIRC
Edited by Joe C on 17th Oct, 2008.
why not, well for a road car IMO it would be helpful to have a lower then 1.1 ratio for a 5th gear, other wise why don't i just fit a 2.7 diff to my 4 gears and save £1500, as i'll gain not revs and economy from it!
Scruffy
Member #: 328
Cos most cars won't pull a 2.7 without loosing too many revs on each gearchange. Fitting a 2.7 to a four speed would be like having a 3.1 on a conventional overdrive (0.865) ratio 5 speed except the power loss in 5th would be less as it is 1:1.
Hedgemonkey
Member #: 360
I like the look of the KAD box very much. Trapaezoid dogs have a longer life than involute dogs and engage better than "bean" dogs. It's a beautiful piece of engineering. The snag is close ratios. I accidentally bought a challenge gearkit and it has the problem inherant to powerful engines, whether they be FI or big capacity. You need a good spread of gears.
I'm sure that people will disagree, but overdriven 5th's are prone to huge bearing loads, especially if helical. I like the idea of a straight through 5th and a lower first, running a longer legged FD.
The KAD 2.4 first is lower than my ST 2.54 first which limits my final drive choice. Either that or it's a clutch plate a week. (when it's working! )
The KAD box is a beautiful design and if there were a set of spread ratios, it would make so much sense, I can't understand it, coming from people who build serious engines. You just don't need those ratios, unless you are doing rolling starts or racing short stroke screamers in the 60's.
Someone will do it at some point, as there is clearly a demand for a quick changing 5 speed box which allows a better spread of gears/speed.
It will happen in due course.
do you mean higher stu?
Hedgemonkey
Member #: 360
I always get it the wrong way around. Longer legged!
Higher!
