Home > General Chat > 1275 MG Metro Turbo Engine Breaking, Whats it worth?
robba_duck
Member #: 4127
As per title I Will shortly be selling (in the for sale Bit) a 1275 turbo engine
The Turbo and head are already gone.
I would like an idea of what the bits left are worth.
I.e Crank, Gear box, Block, pistons, the little turbo oil return dooh dah on back of block
the gear Box looks Perfect and has a 3.2 diff.
the engine was rebuilt and only did a few miles Very clean inside no wear on the timing tensioner!,
The flywheel looks like new, including back plate
There is a duplex timing chain
electronic dizzy (i have been told turbo dizzys are differant to normal ones)
The crank Is marked CAM 6581
Or a price for the whole lot?
sure more will come to mind !
Thanks everyone
just_jack
Member #: 2928
peterborough
is the duplex chain a vernier or just normal
thanks
jack
Jack Jones
robba_duck
Member #: 4127
just normal sorry.
worth bugger all
Jason G
Member #: 1459
En-suite user
Braintree, Essex
alot of people use standard N/A 1275 parts, theres not alot of difference.
Theres the difference of opinion on cranks, most of the high power motors on here use the CAM 6232.
On 19th Jan, 2010 wil_h said:
Mr Joshua
Member #: 1954
Luton Bedfordshire
What cam is fitted?
Own the day
When you say the engine has been rebuilt, what does this entail? full rebuild and rebore? or simply new bearings and rings?
Mr Joshua
Member #: 1954
Luton Bedfordshire
If I am not mistaken what you have left is basicaly a 1275 mafair lump with a few extra bits.
Own the day
