| Home > Wanted > wiper witing loom | |||||||
126 Posts Member #: 244 Advanced Member |
29th Aug, 2004 at 10:35:37pm
I recently modified my wiring loom after an electrical fault, trouble is that I removed the part of the loom for the wipers and washer pump, my problem now is that that section of loom got accidentally binned! Speedster turbo under construction |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
29th Aug, 2004 at 11:24:49pm
maybe..... ive got a couple of old looms in the garage. what exactly are you after? will it be obvious when i look? hopefully i will be a bit more alert tomorrow, i would imagine its fairly obvoius... And on the 7th day........... God created turbochargers! |
30th Aug, 2004 at 10:49:28am
it is fairly plain to see, it is a connector (5 wire, I THINK) that would normally sit on the passenger side inner wing. With a bit of on-picking this turns out to the fuse box, a black connector that normally plugs in to the steering column stalks and a white 2 way connector that plugs in to the washer pump on the drivers side inner wing at the front. Like I said previously said, you will need to cut 2 black (negative) feeds from a ring terminal that normally lives under the bonnet on the drivers side.
1st Sep, 2004 at 05:30:17pm
BUMP! Anyone else help me with this?
6th Sep, 2004 at 08:03:45pm
forget it, bought one on e-bay! £10 inc P&P
6th Sep, 2004 at 10:34:26pm
shit!!! really sorry mate, i completely forgot to look! bugger! glad you got it sorted tho!
