| Home > Help Needed / General Tech Chat > ARP bolts fouled gearbox | |||||||
21st Oct, 2008 at 10:20:17pm
Ok lads my self and Gary came up agents another small problem, with this long stroke 1098 we fitted ARP bolts to the big ends, and now it seem that the bolt on number 2 con rod are fouling the gearbox on the pinion bearing housing beam, where Carls gearbox broke last time. I am a little weary of grinding material away at this point as this is an inherent weakness of the mini box taught ??
On 17th Feb, 2009 Rob H said:
21st Oct, 2008 at 10:25:48pm
ive only had problems in the rear box, the first was a hairline crack,
21st Oct, 2008 at 10:32:52pm
I've had clearance problems with 1098 cranks before, in my case it was a central oil pick up pipe that fouled. In any case I'd also check this whilst its in bits still.
21st Oct, 2008 at 10:37:48pm
A+ Box?
21st Oct, 2008 at 10:40:37pm
I dont understand you Tom you would check what when what is in bits ?? maby had to much stlla toningt :$
On 21st Oct, 2008 Tom Fenton said:
In any case I'd also check this whilst its in bits still. On 17th Feb, 2009 Rob H said:
21st Oct, 2008 at 10:41:46pm
21st Oct, 2008 at 10:45:03pm
Alright then, check it before you build it totally then.
21st Oct, 2008 at 10:47:22pm
Ahh yup thats what we are at all right you spot on defently to much stella On 17th Feb, 2009 Rob H said:
21st Oct, 2008 at 10:55:36pm
Were there ever any 1100 A+ engines?
21st Oct, 2008 at 11:00:22pm
I think you are spot on Sprocket I was just back down to the work shop and the head of the ARP bolt is sum 1.2mm deeper than the STD bolt so what with this extra length the extra meat on the gearbox web fouling accures how bloody close must the bolts have run in the STD 1098s ??? On 17th Feb, 2009 Rob H said:
