| Home > Help Needed / General Tech Chat > Simplex Timing Chain | |||||||
152 Posts Member #: 2190 Advanced Member South Carolina, USA |
26th Oct, 2008 at 11:27:46pm
I have a simplex timing chain that seems has a lot a slack in it, but no real wear. I have timed the cam and it is 6 degrees retarded.
27th Oct, 2008 at 12:06:58am
27th Oct, 2008 at 01:41:55am
No tensioner... the rubber rings are not doing much of anything. Is it possible to mod my timing chain cover so that I can install a tensioner? Does anyone a a picture of an A+ cover? |
27th Oct, 2008 at 01:49:44am
Actually looking into a bit more...I would also have to mod the front plate... don't think I am going to do a tensioner...
Edited by Mikes1098 on 27th Oct, 2008. |
27th Oct, 2008 at 04:30:14am
The front plate mods are very simple.I use a duplex setup and a tensioner and never hear from the chain again.If you can put up with the noise a slack chain will do, but it will be diffucult to get the valve timing right and the cam timing will "flutter" at low engine speeds -not good on a performance engine I think. |
27th Oct, 2008 at 04:31:48am
BTW, chains dont stretch at all, the pins and bushes wear and this is a continuous process. |
27th Oct, 2008 at 08:54:10am
used to test old bike chains by bending them sideways, if theres much flex, then its time to replace "Turbo's make torque, and torque makes fun"
27th Oct, 2008 at 02:28:20pm
On 27th Oct, 2008 tadge44 said: Oh please! All that matters is that it is known over a period of time the overall length of the chain will increase.
BTW, chains dont stretch at all, the pins and bushes wear and this is a continuous process. Own the day
27th Oct, 2008 at 04:28:23pm
What I was trying to indicate in response to the quote that "I am assuming it will not stretch any more" was that it would continue to "stretch".Sorry if I offended anyones tender sensibilities. |
27th Oct, 2008 at 06:29:09pm
Yes, they "stretch", whatever people take that to mean and why.....
27th Oct, 2008 at 07:21:05pm
where are these rubber rings? I cant visualise? |
27th Oct, 2008 at 07:36:33pm
i use duplex and a+ tensioner |
27th Oct, 2008 at 08:03:52pm
On 27th Oct, 2008 miniminor63 said:
where are these rubber rings? I cant visualise? Then you're too young......:) They were in two grooves machined in the large sprocket of the very early drives just under the outer links of the chain - the idea being the rubber rings pushed the chain outwards from the teeth on the large sprocket... But they went hard very quickly so forgot to push...... :(:(:( Schrödinger's cat - so which one am I ??? |
27th Oct, 2008 at 09:27:54pm
hmm, I may be young, but have never worked on any other a series engines than pre A+... :) Thanks for the answer! |
27th Oct, 2008 at 09:45:07pm
http://www.minispares.com/Product.aspx?ty=...ENSIONER,%20P... On 26th Oct, 2004 TurboDave16v said:
27th Oct, 2008 at 09:47:23pm
hmm, I may be young, but have never worked on any other a series engines than pre A+... :) Thanks for the answer! Sorry, I didn't mean to appear sarcastic or offensive in any way - some features of the early engines were very strange and Mike seems to have a very early engine from some of his other posts (coil spring clutch for example) :):):) Schrödinger's cat - so which one am I ??? |
27th Oct, 2008 at 10:00:12pm
I got it |
28th Oct, 2008 at 12:06:52am
On 27th Oct, 2008 Rod S said:
... Mike seems to have a very early engine from some of his other posts (coil spring clutch for example) :):):) Rod is spot on... I must have the oldest engine ever. It has definitely added a huge challenge to the rebuild. FYI, here is a picture of an old a$$ timing chain gear... which I replaced with a normal gear (without the rubber rings, which I assume is from an A+ with a tensioner) because someone machined the back of this one (which Rod helped out on also). My assumption is that the rubber rings were not doing much of anything before...the engine would never notice that they were missing. |
28th Oct, 2008 at 08:15:12am
Ahhh, I see your dilema, your new sprocket doesn't have the grooves so you cant fit the rubber rings anyway...
Edited by Rod S on 28th Oct, 2008. Schrödinger's cat - so which one am I ??? |
28th Oct, 2008 at 08:40:57am
Soo pleased you got there ! I have been mucking about with A series for so long I no longer remember which bits fit which, so I was getting a bit worried that I had misdirected everyone.New cover definitely. |
28th Oct, 2008 at 08:48:23am
My mistake entirely.....
28th Oct, 2008 at 06:03:14pm
You could do worse than buy one of TD's new fangled aluminum On 26th Oct, 2004 TurboDave16v said:
28th Oct, 2008 at 06:05:24pm
Ahhh, but does he do new fangled aluminium covers to go with them Schrödinger's cat - so which one am I ??? |
28th Oct, 2008 at 06:12:14pm
On 28th Oct, 2008 Rod S said:
Ahhh, but does he do new fangled aluminium covers to go with them ![]() Thats Paul Wigintons department
29th Oct, 2008 at 12:20:58am
Mike, if you can get hold of a later cover, the rest is a bargain price in the UK at the moment http://www.minispares.com/Product.aspx?ty=...R%206%20PIECE... That is an amazing price! Just the tensioner mounting plate is $60.00 here vs everything $20 there... http://www.minimania.com/web/Item/12G2628/InvDetail.cfm I think I might just buy this kit and find a cover somewhere... Thanks guys for all your help. Rod the side by side pictures are great, thanks for going through the effort - personally pictures are worth a thousand words to me. It is amazing the thought the engineers back then put into using the same front plate by just adding a few holes. Edited by Mikes1098 on 29th Oct, 2008. |
did not feel offended in any way:)
It's an optical illusion because of the gasket outline...
backplates. AND he is on the same continent
