Home > Wanted > 1275 A+ Block
As title really. I need a 1275 A+ Block without liners including all of the main caps.
Must be on a standard bore and be in good enough condition to go to 1293cc.
In the Essex/Hertfordshire area if possible.
Thanks
Actually. I'm not fussed if it has liners or not.
stefaz
Member #: 1656
stoke-on-trent
got one with liners, all the main caps, centre machined flat already and with the crank which needs a regrind if you want it
I'd take if I wasn't 3 hours away. lol
It would cost too much to send via the postie.
stefaz
Member #: 1656
stoke-on-trent
how desperate are you for it mate? sure there was a postal firm thatd do it for about 20 notes a while back mentioned on here and i can always nick pallets from work lol
Mr Joshua
Member #: 1954
Luton Bedfordshire
Think I got 3. Live in Luton if thats good for you.
Own the day
Ah, Luton is closer.
1 will do the trick. You have PM.
