| Home > Show Us Yours! > Latest damage to the clutch! | |||||||
28th Oct, 2008 at 09:34:43pm
Well after the saturday night special at santapod i came home with a slipping clutch and a bad hangover! I only managed to take the engine out at the weekend, to check the clutch and for a winter tune up! The pictures below speak a thousand words! Was using my slicks and just had too much grip for a hard launch Its just lunched the clutch |
28th Oct, 2008 at 09:55:56pm
the flywheel and backplate should face up.can't see any reason to replace,
28th Oct, 2008 at 10:03:01pm
Thats just what i wanted to hear! I was hoping i would be able to get the flywheel and backplate faced as its not very old! Weight saving is part of the winter project as there can be alot more done yet. I was looking at the double grey but was worried about the thrusts! I had forgot about oil feeding them i will have to have a search for your posts! |
28th Oct, 2008 at 10:05:51pm
i would go fror AP race plate and double grey .... forget the alcon paddle plate theyre shite in my book not enough contact area on only around 50% ish... think about it ?
Edited by BENROSS on 28th Oct, 2008.
28th Oct, 2008 at 10:12:06pm
bet that smelt a goodun!! |
28th Oct, 2008 at 10:21:23pm
I have just got a ap race plate from dan on here and i would say there is even less contact area, the lug mod wasn't carried out as it was a rush job before avonpark this year! Im just glad it died at the last event, it gives me an excuse to rebuild it to a better spec! They don't smell at all but it did squeal! |
29th Oct, 2008 at 07:37:31am
do not machine the lugs without measuring. It might well be that MED has already designed that into the backplate, as its a aftermarket one, and not a modified standard one. |
29th Oct, 2008 at 07:56:59am
Good words, i have 3mm in total machined off one of my plates. Didnt work too well.
On 29th Oct, 2008 miniminor63 said:
do not machine the lugs without measuring. It might well be that MED has already designed that into the backplate, as its a aftermarket one, and not a modified standard one. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
29th Oct, 2008 at 10:31:37am
Proper job When you get it to turn blue and gold! Own the day
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
30th Oct, 2008 at 01:34:19pm
yeah, that's pretty brutal...
24th Dec, 2008 at 12:34:46pm
Well recently I have been getting A few pieces together for rebuilding the engine/clutch. I took the the flywheel and backplate to my local machine shop, Had the flywheel skimmed but he couldnt get a good enough finish as he said it was just too hard! The Backplate was more warped than a bannana. So i have ordered new parts from MED. Im going to use a paddle again but this time with a double grey just struggling to get one at the minute! I have also had the thrust oilfed as per Fastcarl!
24th Dec, 2008 at 01:08:51pm
How much power are you putting out? The double gray sounds so overkill.. On 13th Jul, 2012 Ben H said:
24th Dec, 2008 at 01:16:49pm
I dont honestly know how much power im running never been on the rollers. Vegard the clutch maybe overkill but I dont see the point in refreshing the clutch with the same bits too do the same again and i cant afford to keep replacing it! I think using proper drag slicks is putting to much stress on the clutch when it gets dropped at 5000rpm if the double grey cant cope then its time to try something else! |
Looking into what the options are now? it was a med flywheel and backplate with a alcon paddle and a grey cover!
