| Home > Help Needed / General Tech Chat > Brake pedal arm clevis pin (problem #2) | |||||||
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
30th Oct, 2008 at 04:48:07pm
I know this should be simple. I've rebuilt an entire car so this is irritating;
30th Oct, 2008 at 05:01:59pm
depending on age of car ther is either an "E" clip or "R" clip preventing the pin from sliding out. Its a pig of a jobyou wiil have to get your head right into the foot well to get a look at it. Own the day
30th Oct, 2008 at 05:02:43pm
I assume you mean the pin that connects the pedal to the rod which runs up through the bulkhead?
Edited by Rob Gavin on 30th Oct, 2008. |
30th Oct, 2008 at 05:06:50pm
The servo type brake pedal is different to the non servo type pedal.
30th Oct, 2008 at 05:12:29pm
On 30th Oct, 2008 Tom Fenton said: Pleb how the hec could I get that mixed up! As above swap in a complete pedal box if one is to hand.
The servo type brake pedal is different to the non servo type pedal. The non-servo type pedal does have a removeable clevis pin, as the pedal attaches direct to the master cylinder fork. The servo type pedal has a pushrod machine rivetted to it that cannot be removed, as you connect this pushrod to the servo linkage from under the bonnet. I suspect you have been trying to remove this pushrod from a servo type pedal; in short forget it, you could get it out with a grinder if the pedal was removed, but the pedal would have in it the wrong size hole (too big) for the master cylinder. You can swap over an earlier type brake pedal into your pedal box but you will find it will sit at a different angle to the clutch pedal. Best way is to get hold of an early type pedal box and fit it complete. Own the day
30th Oct, 2008 at 07:16:28pm
Argh. *Expletive*
30th Oct, 2008 at 08:25:04pm
I would have thought someone will have a cheap pedal box for you |
