| Home > Help Needed / General Tech Chat > Supercharger 5 port cylinder head/cam thoughts. | |||||||
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
2nd Sep, 2004 at 06:31:27pm
So, I have a blank 12G940 and am probably going to keep the valves the same. In my estimation higher lift should be fine keeping the valves (MG) the same size. Hopefully if I can get some +20 LC pistons (8:1) I will not be needing to sculpt the head too much. As I will not be running a turbo, I can get away with a lower CR as I should have no lag to make up for. If I need more CR, I will go along Vizards lines. Bugger off, I'm getting there. |
3rd Sep, 2004 at 08:35:22pm
lot of sense in there... You've obvioulsy got a good understanding of forced induction...
146 Posts Member #: 350 Turboing minis since '89<br> Supercharging minis since '04 |
6th Sep, 2004 at 10:54:50pm
think of it as if your making for example 150 bhp are the standard ex valves and ports going to be big enough , really its big exhaust work because the intake charge is being forced in
