Home > Help Needed / General Tech Chat > dashpot questions
stockodaz
Member #: 4055
teeside
hi was wondering if anybody could help the turbo engine in my car is ticking over well to high checked for air leaks everything seems ok was fiddling with dashpot and if i undo plunger and use it to slightly raise tube it sits in cars idle drops to normal is there any way i can adjust height of tube in dashpot i have filled to top with 20/50 oil is this correct or is it to much tried adjusting mixture screw but it has no effect whatsoever to idle speed any help comments greatly appreciated as i have absolutly no knowledge with regards to dashpots
Turbo Shed
Member #: 30
Epsom, Surrey
have you tried adjusting the idle screw on the carb?
tadge44
Member #: 2500
Buckinghamshire
Also check that the needle is properly inserted in the piston and secure.
