| Home > Help Needed / General Tech Chat > Strange oil pressure issue | |||||||
2nd Nov, 2008 at 09:17:29pm
Hi
2nd Nov, 2008 at 09:22:18pm
2nd Nov, 2008 at 09:27:00pm
It was very slow to build when the oil had become thicker again when it had stood for 3 hours
2nd Nov, 2008 at 09:50:20pm
on cranking 5 - 10 secons
On 17th Feb, 2009 Rob H said:
3rd Nov, 2008 at 07:20:40pm
Ok
4th Nov, 2008 at 06:23:43am
I suggest that you try a different oil pressure guage.Also bleed the line from the engine to the guage - an air bubble in there can give all sorts of weird readings.Try all the simple things first before getting worried about tearing the engine apart.Different oil filter? |
4th Nov, 2008 at 08:53:51am
On 4th Nov, 2008 tadge44 said:
I suggest that you try a different oil pressure guage.Also bleed the line from the engine to the guage - an air bubble in there can give all sorts of weird readings.Try all the simple things first before getting worried about tearing the engine apart.Different oil filter? I did think about the pressure guage and filter last night, I'll give them a go. On 7th Oct, 2010 5haneJ said:
4th Nov, 2008 at 09:31:16am
sounds like crud in the capilary pipe or gauge, as above, try a different gauge and pipe. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
7th May, 2009 at 07:34:33pm
I never did mention what was wrong.
